1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Conversion error when using (pvapy served) PVA input link in a "bi" record
From: Nicklas Holmberg via Tech-talk <[email protected]>
Date: Mon, 16 May 2022 11:47:38 +0000
I am using pva input links for two different records, a longin and a bi record. The “longin” record works without any problem, but the “bi” does not.
The error shown in the IOC shell is:
pvaLink long int {anonymous}::pvaGetValue(DBLINK*, short int, void*, long int*) fails my-bi:pvapy-bool: castUnsafeV: Conversion not supported
which, of course, repeats every time the record is processed.
The PVs are served from a python pvapy application, and I have no problem reading them using general EPICS commands like pvget, pvinfo, etc. I use them as input links to the bi and longin records like this:
record(longin, "my-longin:pvapy-int"){
field(INP,      {pva:{
                pv:"plc-ts:PLC:ts_1252_ns",
                proc:"CPP"
record(bi, "my-bi:pvapy-bool"){
field(INP,      {pva:{
                pv:"plc-ts:ptp:synchronized ",
                proc:"CPP"
The IOC uses EPICS 7.0.6.1 and the following st.cmd:
#!/usr/bin/env iocsh.bash
dbLoadRecords("nsrecord.db")
iocInit()
Doing “pvinfo” on the incoming PVs show:
$ pvinfo plc-ts:ptp:synchronized
Server: 10.102.10.19:5075
Type:
    epics:nt/NTScalar:1.0
        boolean value
        string descriptor
        structure alarm
            int severity
            int status
            string message
        structure timeStamp
            long secondsPastEpoch
            int nanoseconds
            int userTag
        structure display
            double limitLow
            double limitHigh
            string description
            string format
            string units
        structure control
            double limitLow
            double limitHigh
            double minStep
$ pvinfo plc-ts:PLC:ts_1252_ns
Type:
        string value
        string descriptor
        structure alarm
            int severity
            int status
            string message
        structure timeStamp
            int nanoseconds
            int userTag
        structure display
            double limitLow
            double limitHigh
            string description
            string format
            string units
        structure control
            double limitLow
            double limitHigh
            double minStep
______________________
Nicklas Holmberg
Senior Engineer, ICS HWI
European Spallation Source ERIC
P.O. Box 176, SE-221 00 Lund, Sweden
Visiting address: Partikelgatan 2, 224 84 Lund
Mobile: +46 76 168 06 60
E-mail: [email protected]
ess.eu
Re: Conversion error when using (pvapy served) PVA input link in a "bi" record Michael Davidsaver via Tech-talk
Prev: Re:AW: pv invalid using stream 网易邮件中心 via Tech-talk
Next: Re: Conversion error when using (pvapy served) PVA input link in a "bi" record Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Regex support in StreamDevice. Li, Ji via Tech-talk
