1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Conversion error when using (pvapy served) PVA input link in a "bi" record
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Nicklas Holmberg <[email protected]>
Date: Mon, 16 May 2022 22:29:07 -0700
On 5/16/22 04:47, Nicklas Holmberg via Tech-talk wrote:
I am using pva input links for two different records, a longin and a bi record. The “longin” record works without any problem, but the “bi” does not.
This is the expected behavior of QSRV as currently defined.
A biRecord (enumeration with two labels) isn't the same as
a PVA boolean type.  To map into bi or mbbi records, your
PVA server should provide an NTEnum.
The error shown in the IOC shell is:
pvaLink long int {anonymous}::pvaGetValue(DBLINK*, short int, void*, long int*) fails my-bi:pvapy-bool: castUnsafeV: Conversion not supported
which, of course, repeats every time the record is processed.
The PVs are served from a python pvapy application, and I have no problem reading them using general EPICS commands like pvget, pvinfo, etc. I use them as input links to the bi and longin records like this:
record(longin, "my-longin:pvapy-int"){
field(INP,      {pva:{
                 pv:"plc-ts:PLC:ts_1252_ns",
                 proc:"CPP"
record(bi, "my-bi:pvapy-bool"){
field(INP,      {pva:{
                 pv:"plc-ts:ptp:synchronized ",
                 proc:"CPP"
The IOC uses EPICS 7.0.6.1 and the following st.cmd:
#!/usr/bin/env iocsh.bash
dbLoadRecords("nsrecord.db")
iocInit()
Doing “pvinfo” on the incoming PVs show:
$ pvinfo plc-ts:ptp:synchronized
Server: 10.102.10.19:5075
Type:
     epics:nt/NTScalar:1.0
         boolean value
         string descriptor
         structure alarm
             int severity
             int status
             string message
         structure timeStamp
             long secondsPastEpoch
             int nanoseconds
             int userTag
         structure display
             double limitLow
             double limitHigh
             string description
             string format
             string units
         structure control
             double limitLow
             double limitHigh
             double minStep
$ pvinfo plc-ts:PLC:ts_1252_ns
Type:
         string value
         string descriptor
         structure alarm
             int severity
             int status
             string message
         structure timeStamp
             int nanoseconds
             int userTag
         structure display
             double limitLow
             double limitHigh
             string description
             string format
             string units
         structure control
             double limitLow
             double limitHigh
             double minStep
______________________
*Nicklas Holmberg*
Senior Engineer, ICS HWI
*European Spallation Source ERIC*
P.O. Box 176, SE-221 00 Lund, Sweden
Visiting address: Partikelgatan 2, 224 84 Lund
Mobile: +46 76 168 06 60
E-mail: [email protected] <mailto:[email protected]>__
ess.eu <ess.eu>__
RE: Conversion error when using (pvapy served) PVA input link in a "bi" record Nicklas Holmberg via Tech-talk
Prev: Conversion error when using (pvapy served) PVA input link in a "bi" record Nicklas Holmberg via Tech-talk
Next: Segmentation fault (core dumped) Error cl47cl--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: RE: Conversion error when using (pvapy served) PVA input link in a "bi" record Nicklas Holmberg via Tech-talk
