Thanks! But what EPICS record type should I then use to read a PVA Boolean type, like the "plc-ts:ptp:synchronized" PV described below? My end goal is to have a PV served from my IOC, which can be picked up by the Archiver service.
Best regards,
Nicklas Holmberg
Senior Engineer
Hardware and Integration Group
ICS Division
+46761680660
-----Original Message-----
Sent: den 17 maj 2022 07:29
To: Nicklas Holmberg <[email protected]>
Cc: [email protected]
Subject: Re: Conversion error when using (pvapy served) PVA input link in a "bi" record
On 5/16/22 04:47, Nicklas Holmberg via Tech-talk wrote:
> Hi,
> I am using pva input links for two different records, a longin and a bi record. The “longin” record works without any problem, but the “bi” does not.
This is the expected behavior of QSRV as currently defined.
A biRecord (enumeration with two labels) isn't the same as a PVA boolean type. To map into bi or mbbi records, your PVA server should provide an NTEnum.
> The error shown in the IOC shell is:
> pvaLink long int {anonymous}::pvaGetValue(DBLINK*, short int, void*,
> long int*) fails my-bi:pvapy-bool: castUnsafeV: Conversion not
> supported
> which, of course, repeats every time the record is processed.
> The PVs are served from a python pvapy application, and I have no problem reading them using general EPICS commands like pvget, pvinfo, etc. I use them as input links to the bi and longin records like this:
> record(longin, "my-longin:pvapy-int"){
> field(INP, {pva:{
> pv:"plc-ts:PLC:ts_1252_ns",
> proc:"CPP"
> record(bi, "my-bi:pvapy-bool"){
> field(INP, {pva:{
> pv:"plc-ts:ptp:synchronized ",
> proc:"CPP"
> The IOC uses EPICS 7.0.6.1 and the following st.cmd:
> #!/usr/bin/env iocsh.bash
> dbLoadRecords("nsrecord.db")
> iocInit()
> Doing “pvinfo” on the incoming PVs show:
> $ pvinfo plc-ts:ptp:synchronized
> Server: 10.102.10.19:5075
> Type:
> epics:nt/NTScalar:1.0
> boolean value
> string descriptor
> structure alarm
> int severity
> int status
> string message
> structure timeStamp
> long secondsPastEpoch
> int nanoseconds
> int userTag
> structure display
> double limitLow
> double limitHigh
> string description
> string format
> string units
> structure control
> double limitLow
> double limitHigh
> double minStep
> $ pvinfo plc-ts:PLC:ts_1252_ns
> Type:
> string value
> string descriptor
> structure alarm
> int severity
> int status
> string message
> structure timeStamp
> int nanoseconds
> int userTag
> structure display
> double limitLow
> double limitHigh
> string description
> string format
> string units
> structure control
> double limitLow
> double limitHigh
> double minStep
> ______________________
> *Nicklas Holmberg*
> Senior Engineer, ICS HWI
> *European Spallation Source ERIC*
> P.O. Box 176, SE-221 00 Lund, Sweden
> Visiting address: Partikelgatan 2, 224 84 Lund
> Mobile: +46 76 168 06 60
> E-mail: [email protected] <mailto:[email protected]>__
> ess.eu <ess.eu>__
- Conversion error when using (pvapy served) PVA input link in a "bi" record Nicklas Holmberg via Tech-talk
- Re: Conversion error when using (pvapy served) PVA input link in a "bi" record Michael Davidsaver via Tech-talk
Segmentation fault (core dumped) Error cl47cl--- via Tech-talk
P4P monitor get pvname Florian Feldbauer via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
