1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Octal escape sequence translation issue in base 7.0.6.1?
To: "Wlodek, Jakub" <[email protected]>
Date: Wed, 18 May 2022 00:50:37 +0000
Hi Jakob,
That’s what I did too. I also changed it in the example st.cmd in ADPilatus.
Sent from my iPhone
On May 17, 2022, at 7:45 PM, Wlodek, Jakub via Tech-talk <[email protected]> wrote:
Hi Mark,
We also recently ran into this configuring a Pilatus detector at NSLS2 with recent versions of base/areaDetector. Indeed, as Andrew said, the solution we found was to change "\030" to "\x18" which is the two digit hex equivalent.
Best,
Jakub
From: Tech-talk <[email protected]> on behalf of Andrew Johnson via Tech-talk <[email protected]>
Sent: Tuesday, May 17, 2022 5:34 PM
To: [email protected] <[email protected]>
Hi Mark,
On 5/17/22 4:17 PM, Mark Rivers via Tech-talk wrote:
Folks,
I just switched to using base 7.0.6.1 on my beamlines.  When I try to start a Pilatus detector I get this error:
# Set the input and output terminators.
asynOctetSetInputEos("camserver", 0, "\030")
Set EOS failed: camserver illegal eoslen 3
It appears that it is interpreting the escape sequence \030 as a string of 3 characters rather than as a single character.  Is this a bug in base 7.0.6.1 or a problem with my syntax?  This used to work fine with base 7.0.4, I have not changed anything.
I assume iocsh is using epicsString.h functions to interpret the escapes inside parameters, these changes appeared in EPICS 7.0.5:
Character Escape Changes
  • The libCom routines epicsStrnRawFromEscaped() and dbTranslateEscape() declared in epicsString.h no longer accept octal escaped characters such as \123 or \41.
  • The routine epicsStrnEscapedFromRaw() now generates hex excaped characters for unprintable characters such as \x1f.
  • Hex escape character sequences \xXX must now contain exactly 2 hex digits.
  • An escape sequence \0 now generates a zero byte in the raw string, but the other digits 1-9 should not appear after a back-slash.
These changes are to more closely follow the JSON5 standard, which doesn't support octal character escapes or the \a (Bel, \x07) escape sequence.
2-digit hex \xXX escapes should work fine on both sides of the change.
- Andrew
Complexity is free, it's Simplicity that takes work.
Octal escape sequence translation issue in base 7.0.6.1? Mark Rivers via Tech-talk
Re: Octal escape sequence translation issue in base 7.0.6.1? Andrew Johnson via Tech-talk
Re: Octal escape sequence translation issue in base 7.0.6.1? Wlodek, Jakub via Tech-talk
Prev: Re: Octal escape sequence translation issue in base 7.0.6.1? Wlodek, Jakub via Tech-talk
Next: autosave problem Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
