1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: autosave problem
To: "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 18 May 2022 22:08:42 +0000
Hi Andrew,
Ø  Were there any changes to your file-server? I'm hoping that's not the system that Mrinal was upgrading to CentOS-8 last week.
The file server has not changed, it is Centos 7.
Ø  1058 bytes is less than a single UDP packet; can you try writing some other largeish file from VxWorks, just to make sure that isn't related. There is a "copy" command which might work for that, you give it an existing filename and a new one.
I just copied a file of about 16 kB  using the vxWorks shell.
ioc13ida> copy "motors.template","junk.txt"
value = 0 = 0x0
It worked fine, the output file junk.txt is the same as the input file.
corvette:CARS/iocBoot/ioc13ida>ls -l motors.template junk.txt
-rwxrwxrwx 1 epics domain users 16959 Jan  1  2020 junk.txt
-rwxrwxr-x 1 epics domain users 16959 Jan  1  2020 motors.template
I am adding some debugging to save_restore:write_it to figure out which fprintf failed and perhaps why.
Sent: Wednesday, May 18, 2022 4:59 PM
To: Mark Rivers <[email protected]>; [email protected]
Cc: [email protected]
Subject: Re: autosave problem
Hi Mark,
Were there any changes to your file-server? I'm hoping that's not the system that Mrinal was upgrading to CentOS-8 last week. 1058 bytes is less than a single UDP packet; can you try writing some other largeish file from VxWorks, just to make sure that isn't related. There is a "copy" command which might work for that, you give it an existing filename and a new one.
- Andrew
On 5/18/22 4:52 PM, Mark Rivers wrote:
Folks,
I just upgraded my VME IOCs to base 7.0.6.1 and the master branch of autosave (some changes since 5-10-2).  I am getting these errors at the vxWorks prompt:
ioc13ida> save_restore:write_it: fprintf returned 0 [220518-163829].
save_restore:write_it: Giving up on this attempt to write 'auto_settings.sav'. [220518-163829]
save_restore:write_save_file: Can't write save file. [220518-163829]
Recent files in the autosave/ directory are:
-rw-rw-rw- 1 epics domain users   2749 May 18 16:37 auto_positions.sav_220518-163750
-rw-rw-rw- 1 epics domain users   1058 May 18 16:37 auto_settings.sav_RBAD_220518-163750
-rw-rw-rw- 1 epics domain users   1058 May 18 16:37 auto_settings.sav_220518-163751
-rw-rw-rw- 1 epics domain users   1058 May 18 16:37 auto_settings.sav_RBAD_220518-163751
-rw-rw-r-- 1 epics domain users   2749 May 18 16:37 auto_positions.sav
-rw-rw-rw- 1 epics domain users   2749 May 18 16:37 auto_positions.savB
-rw-rw-r-- 1 epics domain users   1058 May 18 16:41 auto_settings.sav
Note that it is writing files.  However, the auto_settings.sav file is only 1058 bytes long, while it should be about 160 kB.  It seems like save_restore:write_it is writing some information to the file and then it gets an error.
This is the contents of the auto_settings.sav file:
corvette:iocBoot/ioc13ida/autosave>more auto_settings.sav
# autosave R5.3 Automatically generated - DO NOT MODIFY - 220518-164400
13IDA:ip2:SAUTOS 0
13IDA:ip2:DIS 0
13IDA:ip2:SSIZE 400
13IDA:ip2:ULCK 1
13IDA:ip2:SIZE.SCAN 6
13IDA:ip2:STAT.SCAN 6
13IDA:ip8:SAUTOS 0
13IDA:ip8:DIS 0
13IDA:ip8:SSIZE 400
13IDA:ip8:ULCK 0
13IDA:ip8:SIZE.SCAN 4
13IDA:ip8:STAT.SCAN 6
13IDA:ip9:SAUTOS 0
13IDA:ip9:DIS 0
13IDA:ip9:SSIZE 400
13IDA:ip9:ULCK 0
13IDA:ip9:SIZE.SCAN 4
13IDA:ip9:STAT.SCAN 6
13IDA:tsp1:TSP_FIL 0
13IDA:tsp1:TSP_AUTO_ADV 0
13IDA:tsp1:TSP_VALUE 50
13IDA:tsp1:TSP_UNITS 0
13IDA:tsp1:TSP_SECONDS 50
13IDA:tsp1:TSP_MINUTES 240
13IDA:tsp1:TSP_NCYCLES 900
13IDA:tsp1:TSP_MIN_PRESS 1e-10
13IDA:tsp1:TSP_STAT.SCAN 9
13IDA:DMM1dmm_chan.VAL 1
13IDA:DMM1ch_mode_sel.VAL 6
13IDA:DMM1init_string.VAL *rst;form:elem read
13IDA:DMM1onesh_cont.VAL 1
13IDA:DMM1single_multi.VAL 1
13IDA:DMM1scanner.SCAN 6
13IDA:DMM1Dmm_raw.DESC Dmm raw desc
13IDA:DMM1Dmm_calc.DESC Dmm Units
13IDA:DMM1Dmm_calc.PREC 4
13IDA:DMM1Dmm_calc.SCAN 0
13IDA:DMM1Dmm_calc.CALC A
13IDA:DMM1Dmm_calc.INPA 13IDA:DMM1Dmm_raw.VAL NPP NMS
13IDA:DMM1Dmm_calc.INPB
The disk that autosave it writing to has plenty of room.  What could be causing this error.
It is happening on all 8 of my VME IOCs, it is not just with one of them.
Complexity is free, it's Simplicity that takes work.
RE: autosave problem Mark Rivers via Tech-talk
Re: autosave problem Johnson, Andrew N. via Tech-talk
Prev: Re: autosave problem Johnson, Andrew N. via Tech-talk
Next: RE: autosave problem Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
