1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: procServer unix socket configuration
To: Ralph Lange <[email protected]>
Date: Tue, 24 May 2022 13:03:27 -0700
Hi Ralph,
The *-x* option could be a real benefit for the end-user because it shows at the beginning of the output from the procServ. I add that option into our procSever options.
Thank you,
Han
On Tue, May 24, 2022 at 12:01 AM Han Lee <[email protected]> wrote:
Hi Ralph,
By default that `con` has its own "detaching" command (CTRL-a). I confirmed that at least iocStats heartbeat PV value increases continuously after attaching (con -c /tmp/socket) and detaching (CTRL-a).
Han
On Mon, May 23, 2022 at 11:42 PM Ralph Lange via Tech-talk <[email protected]> wrote:
Well,
If logging out (detaching) from a running IOC is the missing functionality, let me point you back to the procServ man page:
----- snip -----
Any connection (control or log) can be disconnected using the client's
disconnect sequence. Control connections can also be disconnected by sending
the logout command character that can be specified using the *-x*
(*\--logoutcmd*) option.
----- snip -----
This option will let you define a control character to have the procServ server disconnect the client session from the procServ side.
Intended for clients that don't offer a disconnect sequence.
Cheers,
~Ralph
Jeong Han Lee, Dr.rer.nat
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
1 Cyclotron Road Mailstop 46R0161
Berkeley, CA 94720, United States
Tel :+1-510-486-6163
Cell:+1-510-384-3868
procServer unix socket configuration Han Lee via Tech-talk
Re: procServer unix socket configuration Ralph Lange via Tech-talk
Re: procServer unix socket configuration Han Lee via Tech-talk
Re: procServer unix socket configuration Michael Davidsaver via Tech-talk
Prev: Re: Ability to change a record in an IOC when another IOC is exited Ralph Lange via Tech-talk
Next: Re: Can't create mutex semaphore: too many Till Straumann via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: procServer unix socket configuration Han Lee via Tech-talk
Next: Re: PVXS release 0.3.0 and P4P 4.0.1 Michael Davidsaver via Tech-talk
