1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: kafka alarm server does not acknowledge
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Geoffrey Savage <[email protected]>
Date: Thu, 26 May 2022 20:33:50 +0000
> I don't see the acknowledge command messages being received by kafka using the monitor_topic.sh command.
Make sure you monitor the ..Command topic. Assuming your alarm configuration root is "Accelerator", then
 monitor_topic.sh Accelerator
should show the status changes, including a channel entering the alarm state.
Looks like that part works fine because your UI also indicates alarms.
In a second terminal,
 monitor_topic.sh AcceleratorCommand
should show the acknowledgement, something like
command:/Accelerator/DemoSystem/SomePV: {"user":"xxx","host":"xxx.site.org","command":"acknowledge"}
If the UI shows the alarms, then it should also write to the appropriate ..Command topic.
But it's possible that the Accelerator, AcceleratorCommand and AcceleratorTalk topics weren't properly configured in Kafka.
Run
 list_topics.sh
to see if they are.
In the setup, https://github.com/ControlSystemStudio/phoebus/blob/master/app/alarm/Readme.md, note the suggestion to configure Kafka to NOT automatically create topics on first access,
  auto.create.topics.enable=false
and instead use the script
 create_alarm_topics.sh Accelerator
to create Accelerator, AcceleratorCommand and AcceleratorTalk as necessary, with the first one 'compacted' etc.
-Kay
From: Tech-talk <[email protected]> on behalf of Geoffrey Savage via Tech-talk <[email protected]>
Sent: Thursday, May 26, 2022 4:20 PM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] kafka alarm server does not acknowledge
We have setup the kafka based alarm server from phoebus.  We receive alarms in all three UIs but are unable to acknowledge the alarms.
Any idea if this is a kafka configuration issue or I don't understand how alarm acknowledgement works?
Geoff
kafka alarm server does not acknowledge Geoffrey Savage via Tech-talk
Prev: kafka alarm server does not acknowledge Geoffrey Savage via Tech-talk
Next: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: A module for LabMax laser power/energy meter (Coherent) Jong Woo Kim via Tech-talk
