1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: stream feature which similar wireshark
From: "Zimoch Dirk \(PSI\) via Tech-talk" <[email protected]>
To: 网易邮件中心 <[email protected]>
Date: Sat, 4 Jun 2022 12:02:59 +0000
Hello Liang,
Yes, StreamDevice can receive messages sent by the device automatically. The record must use SCAN „I/O Intr“ and the protocol starts with an in command instead of out.
For a more specific answer I need more details on your device. Does it use TCP or UDP? How to configure where it sends to? This is needed to use the correct type of asyn port.
Best regards,
Dirk
Am 04.06.2022 um 10:26 schrieb 网易邮件中心 <[email protected]>:
Hi Dirk,
    I have a feature question about stream.
    I have a device, communicated with PC throuth network card. The process was done by itself, I mean it send and recevie automaticly without EPICS.
    And could I got the receive message,using EPICS stream?
    I puzzled that, normally stream send the out command, then get the in message. Now the device send and recive by itself, could stream( in PC) get the in message?
Liang
stream feature which similar wireshark 网易邮件中心 via Tech-talk
Prev: stream feature which similar wireshark 网易邮件中心 via Tech-talk
Next: Building EPICS MOTOR with just a subscription to only the motorNewport module Timothy Speight - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
