1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Subject: Building EPICS MOTOR with just a subscription to only the motorNewport module
From: Timothy Speight - STFC UKRI via Tech-talk <tech-talk at aps.anl.gov>
To: "'tech-talk at aps.anl.gov'" <tech-talk at aps.anl.gov>
Date: Tue, 7 Jun 2022 11:36:28 +0000
I’ve reverted to commit ‘be5dd3f’ and my module driver and EPICS motor synapps builds OK.
On the latest master for the motorNewport module for an intended complete EPICs motor build;
It seems as though SUPPORT gets redefined!  >>  SUPPORT = $(MOTOR)/..
File in question here :
  https://github.com/epics-motor/motorNewport/blob/master/configure/RELEASE
I’m not sure this last commit is working so well within our build systems here at the CLF.
ERROR: Definition of SUPPORT conflicts with BUSY support.In this application a RELEASE file defines
        SUPPORT = /usr/local/epics/support/motor/motor-R7-2-2/..
Should I raise a PR?
Kind Regards
Tim Speight
Senior Control Systems Software Engineer
Central Laser Facility
Science and Technology Facilities Council
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Re: Building EPICS MOTOR with just a subscription to only the motorNewport module Mark Rivers via Tech-talk
Prev: Re: stream feature which similar wireshark Zimoch Dirk (PSI) via Tech-talk
Next: Re: Building EPICS MOTOR with just a subscription to only the motorNewport module Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
