On 6/8/22 05:41, Kasemir, Kay via Tech-talk wrote:
You can run it with `procs=show`to just print the info,
`procs=db:sqlite3` to use sqlite,
but the main use case it probably `procs=cf` where it uses the channel finder.
fyi. more than one processor can be given. eg.
procs=db:sqlite3, cf
To both store in a local sqlite db file, and push to CF.
- Re: [EXTERNAL] Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address William Kirstaedter via Tech-talk
compile EPICS without examples and tests William Kirstaedter via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
