1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address
From: William Kirstaedter via Tech-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 8 Jun 2022 16:11:34 +0200
thanks, works.
William Kirstaedter (PP&B) Fritz-Haber-Institut der MPG
Faradayweg 4-6 14195 Berlin
Tel: 030 8413 5405 Mail: [email protected]
Am 08.06.2022 um 14:41 schrieb Kasemir, Kay:
> as far as I understand, the recceiver takes the messages of the reccasters and stores them in an sqlite file.
> how does the channelfinder java software access this information?
See the example *.conf files in https://github.com/ChannelFinder/recsync/tree/master/server
You can run it with `procs=show`to just print the info,
`procs=db:sqlite3` to use sqlite,
but the main use case it probably `procs=cf` where it uses the channel finder.
>I'd like to run two instances of the recceiver and only one channelfinder.
You just run as many recceiver instances as you like, all with procs=cf and pointing to the same channel finder.
You likely need to run one recceiver instance per subnet, since IOCs and recceiver find each other via broadcast messages which are typically limited to a subnet.
-Kay
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
Re: [EXTERNAL] Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address Kasemir, Kay via Tech-talk
Prev: Re: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Hartman, Steven via Tech-talk
Next: Re: [EXTERNAL] Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: [EXTERNAL] Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address Kasemir, Kay via Tech-talk
