1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
From: "Hartman, Steven via Tech-talk" <[email protected]>
Date: Wed, 8 Jun 2022 12:43:38 +0000
On Jun 7, 2022, at 4:39 PM, Mark Rivers via Tech-talk <[email protected]> wrote:
Another time I tested the same version it failed with an A32 address error in freeListFree called from db_delete_field_log
Hi Mark—
Next time, can you also include a dump of the memory of the address in r9 (0x03326a90 in these examples)? In both cases, it made it far enough along to put freeListFree into r9, even in the case where the stack trace implicated access happening in db_delete_field_log().
(Great analysis, Till!)
Steven Hartman
[email protected]
RE: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Till Straumann via Tech-talk
RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address Kasemir, Kay via Tech-talk
Next: Re: [EXTERNAL] Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address William Kirstaedter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Next: RE: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
