We need to explain why adding 2 lines of code to examine the contents of pfl eliminates the failures completely.
It’s like a new type of quantum computer - making an observation changes the outcome!
Sent from my iPhone
> On Jun 1, 2022, at 10:24 PM, Michael Davidsaver <[email protected]> wrote:
> On 6/1/22 14:50, Mark Rivers wrote:
>> I checked out R7.0.6.1 and made the following change to dbEvent.c It checks whether pfl or pfl->u.r.dtor are in the VME A32 address space. If they are it prints an error and returns.
> So, these addresses appear in pfl->u.r.dtor or eg. pfl->u.v.field.dbf_float
> My question is then which part(s) of the db_field_log struct have incorrect values?
> (eg. "\xbf\x3e\x00\x1e" as float32 is -0.74)
> One straightforward, though a bit tedious, think to do would be to print a
> dump of the contents of the db_field_log. eg. I'd be interested to know
> if db_field_log::time appears valid.
>> After making that change then one time when I started the IOC I got these messages right after iocInit, which is not when it usually fails.
> This makes me wonder if these "addresses" are eg. somehow valid ADC values,
> which just happen to track through the VME window sometimes. Though if you've
> only loading soft records, I don't see how this could be.
> Further, I still don't see how these values aren't appearing in the register dump.
> I don't think PPC has any instructions which do a double indirection.
> Another odd ball idea which occurs to me is that maybe the compiler is mishandling
> the db_field_log::type bit field. The dbEvent.o which you send to Till and I has:
>> 4c: 80 1f 00 00 lwz r0,0(r31)
>> 50: 2f 80 00 00 cmpwi cr7,r0,0
> If I read things correctly, I think this is meant to correspond to
> 'pfl->u.r.type==dbfl_type_val==0", however it is testing the whole word, and would
> mis-trigger because 'pfl->u.r.ctx == dbfl_context_event == 1` for a monitor update.
> When I look at the result of a local RTEMS build, I think the corresponding is:
>> 8: 89 24 00 00 lbz r9,0(r4)
>> c: 71 29 00 80 andi. r9,r9,128
> Which is testing the high bit as it should.
> For completeness. Disassembly of db_delete_field_log() from dbEvent.o.
> Note that this is object code, with incomplete relocations.
>> 00000034 <db_delete_field_log>:
>> 34: 94 21 ff f0 stwu r1,-16(r1)
>> 38: 7c 08 02 a6 mflr r0
>> 3c: 93 e1 00 0c stw r31,12(r1)
>> 40: 7c 7f 1b 79 mr. r31,r3
>> 44: 90 01 00 14 stw r0,20(r1)
>> 48: 41 82 00 40 beq 88 <db_delete_field_log+0x54>
>> 54: 40 9c 00 18 bge cr7,6c <db_delete_field_log+0x38>
>> 58: 80 1f 00 18 lwz r0,24(r31)
>> 5c: 2f 80 00 00 cmpwi cr7,r0,0
>> 60: 41 9e 00 0c beq cr7,6c <db_delete_field_log+0x38>
>> 64: 7c 09 03 a6 mtctr r0
>> 68: 4e 80 04 21 bctrl
>> 6c: 3d 20 00 00 lis r9,0
>> 70: 7f e4 fb 78 mr r4,r31
>> 74: 80 69 00 00 lwz r3,0(r9)
>> 78: 3d 20 00 00 lis r9,0
>> 7c: 39 29 00 00 addi r9,r9,0
>> 80: 7d 29 03 a6 mtctr r9
>> 84: 4e 80 04 21 bctrl
>> 88: 80 01 00 14 lwz r0,20(r1)
>> 8c: 83 e1 00 0c lwz r31,12(r1)
>> 90: 38 21 00 10 addi r1,r1,16
>> 94: 7c 08 03 a6 mtlr r0
>> 98: 4e 80 00 20 blr
> From my local build for RTEMS-mvme3100
>> void db_delete_field_log (db_field_log *pfl)
>> if (pfl) {
>> 0: 7c 64 1b 79 mr. r4,r3
>> 4: 4d 82 00 20 beqlr
>> /* Free field if reference type field log and dtor is set */
>> if (pfl->type == dbfl_type_ref && pfl->u.r.dtor) pfl->u.r.dtor(pfl);
>> 10: 40 82 00 10 bne 20 <db_delete_field_log+0x20>
>> /* Free the field log chunk */
>> freeListFree(dbevFieldLogFreeList, pfl);
>> 14: 3d 20 00 00 lis r9,0
>> 18: 80 69 00 00 lwz r3,0(r9)
>> 1c: 48 00 00 00 b 1c <db_delete_field_log+0x1c>
>> 20: 81 24 00 50 lwz r9,80(r4)
>> 24: 2f 89 00 00 cmpwi cr7,r9,0
>> 28: 41 be ff ec beq cr7,14 <db_delete_field_log+0x14>
>> 2c: 94 21 ff f0 stwu r1,-16(r1)
>> 30: 7c 08 02 a6 mflr r0
>> 34: 7d 29 03 a6 mtctr r9
>> 38: 90 01 00 14 stw r0,20(r1)
>> 3c: 90 81 00 08 stw r4,8(r1)
>> 40: 4e 80 04 21 bctrl
>> 44: 80 01 00 14 lwz r0,20(r1)
>> 48: 3d 20 00 00 lis r9,0
>> 4c: 80 81 00 08 lwz r4,8(r1)
>> 50: 80 69 00 00 lwz r3,0(r9)
>> 54: 7c 08 03 a6 mtlr r0
>> 58: 38 21 00 10 addi r1,r1,16
>> 5c: 48 00 00 00 b 5c <db_delete_field_log+0x5c>
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Jörn Dreyer via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Re: Alarm-Server within a container Jörn Dreyer via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Till Straumann via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
