On 6/1/22 14:50, Mark Rivers wrote:
I checked out R7.0.6.1 and made the following change to dbEvent.c It checks whether pfl or pfl->u.r.dtor are in the VME A32 address space. If they are it prints an error and returns.
So, these addresses appear in pfl->u.r.dtor or eg. pfl->u.v.field.dbf_float
My question is then which part(s) of the db_field_log struct have incorrect values?
(eg. "\xbf\x3e\x00\x1e" as float32 is -0.74)
One straightforward, though a bit tedious, think to do would be to print a
dump of the contents of the db_field_log. eg. I'd be interested to know
if db_field_log::time appears valid.
After making that change then one time when I started the IOC I got these messages right after iocInit, which is not when it usually fails.
This makes me wonder if these "addresses" are eg. somehow valid ADC values,
which just happen to track through the VME window sometimes. Though if you've
only loading soft records, I don't see how this could be.
Further, I still don't see how these values aren't appearing in the register dump.
I don't think PPC has any instructions which do a double indirection.
Another odd ball idea which occurs to me is that maybe the compiler is mishandling
the db_field_log::type bit field. The dbEvent.o which you send to Till and I has:
4c: 80 1f 00 00 lwz r0,0(r31)
50: 2f 80 00 00 cmpwi cr7,r0,0
If I read things correctly, I think this is meant to correspond to
'pfl->u.r.type==dbfl_type_val==0", however it is testing the whole word, and would
mis-trigger because 'pfl->u.r.ctx == dbfl_context_event == 1` for a monitor update.
When I look at the result of a local RTEMS build, I think the corresponding is:
8: 89 24 00 00 lbz r9,0(r4)
c: 71 29 00 80 andi. r9,r9,128
Which is testing the high bit as it should.
For completeness. Disassembly of db_delete_field_log() from dbEvent.o.
Note that this is object code, with incomplete relocations.
00000034 <db_delete_field_log>:
34: 94 21 ff f0 stwu r1,-16(r1)
38: 7c 08 02 a6 mflr r0
3c: 93 e1 00 0c stw r31,12(r1)
40: 7c 7f 1b 79 mr. r31,r3
44: 90 01 00 14 stw r0,20(r1)
48: 41 82 00 40 beq 88 <db_delete_field_log+0x54>
54: 40 9c 00 18 bge cr7,6c <db_delete_field_log+0x38>
58: 80 1f 00 18 lwz r0,24(r31)
5c: 2f 80 00 00 cmpwi cr7,r0,0
60: 41 9e 00 0c beq cr7,6c <db_delete_field_log+0x38>
64: 7c 09 03 a6 mtctr r0
68: 4e 80 04 21 bctrl
6c: 3d 20 00 00 lis r9,0
70: 7f e4 fb 78 mr r4,r31
74: 80 69 00 00 lwz r3,0(r9)
78: 3d 20 00 00 lis r9,0
7c: 39 29 00 00 addi r9,r9,0
80: 7d 29 03 a6 mtctr r9
84: 4e 80 04 21 bctrl
88: 80 01 00 14 lwz r0,20(r1)
8c: 83 e1 00 0c lwz r31,12(r1)
90: 38 21 00 10 addi r1,r1,16
94: 7c 08 03 a6 mtlr r0
98: 4e 80 00 20 blr
From my local build for RTEMS-mvme3100
void db_delete_field_log (db_field_log *pfl)
if (pfl) {
0: 7c 64 1b 79 mr. r4,r3
4: 4d 82 00 20 beqlr
/* Free field if reference type field log and dtor is set */
if (pfl->type == dbfl_type_ref && pfl->u.r.dtor) pfl->u.r.dtor(pfl);
10: 40 82 00 10 bne 20 <db_delete_field_log+0x20>
/* Free the field log chunk */
freeListFree(dbevFieldLogFreeList, pfl);
14: 3d 20 00 00 lis r9,0
18: 80 69 00 00 lwz r3,0(r9)
1c: 48 00 00 00 b 1c <db_delete_field_log+0x1c>
20: 81 24 00 50 lwz r9,80(r4)
24: 2f 89 00 00 cmpwi cr7,r9,0
28: 41 be ff ec beq cr7,14 <db_delete_field_log+0x14>
2c: 94 21 ff f0 stwu r1,-16(r1)
30: 7c 08 02 a6 mflr r0
34: 7d 29 03 a6 mtctr r9
38: 90 01 00 14 stw r0,20(r1)
3c: 90 81 00 08 stw r4,8(r1)
40: 4e 80 04 21 bctrl
44: 80 01 00 14 lwz r0,20(r1)
48: 3d 20 00 00 lis r9,0
4c: 80 81 00 08 lwz r4,8(r1)
50: 80 69 00 00 lwz r3,0(r9)
54: 7c 08 03 a6 mtlr r0
58: 38 21 00 10 addi r1,r1,16
5c: 48 00 00 00 b 5c <db_delete_field_log+0x5c>
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Till Straumann via Tech-talk
- Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
- RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Torsten Bögershausen via Tech-talk
Re: Alarm-Server within a container Jörn Dreyer via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
