On 5/31/22 07:00, Torsten Bögershausen wrote:
Hej Mark,
So R7.0.5 is good, and f9ea6a5bff695c5f88bb95dce38a3fd349738907 is bad ?
There are some "real" commits, and merges:
git log R7.0.5..f9ea6a5bff695c5f88bb95dce38a3fd349738907
Then it could make sense, to bisect between those 2?
Another question:
Coluld it make sense to run the SW (even more stripped may be)
under Linux instead with valgrind ?
An RTOS without a debugger is just about the worst situation I can imagine
to troubleshoot apparent memory corruption. (excepting maybe having no
console, or it being in orbit)
I've made an attempt to run the database Mark describes with
softIoc+valgrind, and a spam-y python script. Valgrind doesn't
flag any access violates.
The threading checker ("valgrind --tool=helgrind") does flag a possible
race which might be relevant. Or it might be a false positive. I don't
feel that I understand dbEvent.c well enough to say anything conclusive
this late at night.
Possible data race during write of size 8 at 0x5197520 by thread #27
Locks held: 3, at addresses 0x51413A0 0x5143A60 0x5197A10
at 0x48CA60A: db_queue_event_log (dbEvent.c:824)
by 0x48CA732: db_post_events (dbEvent.c:892)
by 0x48595EE: monitor (aoRecord.c:532)
by 0x48595EE: process (aoRecord.c:232)
by 0x48B2C6B: dbProcess (dbAccess.c:608)
by 0x48B4BFF: dbPutField (dbAccess.c:1278)
by 0x48CE9DD: dbChannel_put (db_access.c:923)
by 0x48F6C9A: write_action (camessage.c:799)
by 0x48F7727: camessage (camessage.c:2546)
by 0x48F351F: camsgtask (camsgtask.c:116)
by 0x495E094: start_routine (osdThread.c:439)
by 0x483F876: mythread_wrapper (hg_intercepts.c:387)
by 0x4F1EEA6: start_thread (pthread_create.c:477)
This conflicts with a previous read of size 8 by thread #21
Locks held: none
at 0x48CA99D: event_read (dbEvent.c:999)
by 0x48CA99D: event_task (dbEvent.c:1078)
by 0x4CBADEE: clone (clone.S:95)
Address 0x5197520 is 18,416 bytes inside a block of size 19,528 alloc'd
at 0x48397CF: malloc (vg_replace_malloc.c:307)
by 0x494DBE1: freeListMalloc (freeListLib.c:95)
by 0x494DCE8: freeListCalloc (freeListLib.c:68)
by 0x48C95B2: db_init_events (dbEvent.c:304)
by 0x48D653C: dbContext::subscribe(epicsGuard<epicsMutex>&, dbChannel*, dbChannelIO&, unsigned int, unsigned long, unsigned int, cacStateNotify&, unsigned int*) (dbContext.cpp:221)
by 0x48D7468: dbChannelIO::subscribe(epicsGuard<epicsMutex>&, unsigned int, unsigned long, unsigned int, cacStateNotify&, unsigned int*) (dbChannelIO.cpp:119)
by 0x4EF7771: oldSubscription::oldSubscription(epicsGuard<epicsMutex>&, oldChannelNotify&, cacChannel&, unsigned int, unsigned long, unsigned int, void (*)(event_handler_args), void*, oldSubscription**) (oldSubscription.cpp:43)
by 0x4EF7099: ca_create_subscription (oldChannelNotify.cpp:573)
by 0x48D2BE8: dbCaTask (dbCa.c:1249)
Block was alloc'd by thread #9
https://github.com/epics-base/epics-base/blob/3fadf4a26cfe33dcb9eb9e4620634e1d3a7b9763/modules/database/src/ioc/db/dbEvent.c#L824
https://github.com/epics-base/epics-base/blob/3fadf4a26cfe33dcb9eb9e4620634e1d3a7b9763/modules/database/src/ioc/db/dbEvent.c#L999
$ cat mr-regress.db
record(ao,"testAo_0") {}
record(ao,"testAo_1") {}
record(ao,"testAo_2") {}
record(ao,"testAo_3") {}
record(ao,"testAo_4") {}
record(ao,"testAo_5") {}
record(ao,"testAo_6") {}
record(ao,"testAo_7") {}
record(ao,"testAo_8") {}
record(ao,"testAo_9") {}
record(ai,"testAi_0") {field(INP, "testAo_0 CP") }
record(ai,"testAi_1") {field(INP, "testAo_1 CP") }
record(ai,"testAi_2") {field(INP, "testAo_2 CP") }
record(ai,"testAi_3") {field(INP, "testAo_3 CP") }
record(ai,"testAi_4") {field(INP, "testAo_4 CP") }
record(ai,"testAi_5") {field(INP, "testAo_5 CP") }
record(ai,"testAi_6") {field(INP, "testAo_6 CP") }
record(ai,"testAi_7") {field(INP, "testAo_7 CP") }
record(ai,"testAi_8") {field(INP, "testAo_8 CP") }
record(ai,"testAi_9") {field(INP, "testAo_9 CP") }
$ valgrind --tool=helgrind ./bin/linux-x86_64/softIoc -d mr-regress.db
$ ./bin/linux-x86_64/caput testAo_0 1.0
$ ./bin/linux-x86_64/caput testAo_0 2.0
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Till Straumann via Tech-talk
- RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
- Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Torsten Bögershausen via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
