1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Torsten Bögershausen <[email protected]>, Mark Rivers <[email protected]>, Benjamin Franksen <[email protected]>
Date: Wed, 1 Jun 2022 08:51:04 -0700
On 5/31/22 23:39, Michael Davidsaver wrote:
The threading checker ("valgrind --tool=helgrind") does flag a possible
race which might be relevant.  Or it might be a false positive.  I don't
feel that I understand dbEvent.c well enough to say anything conclusive
this late at night.
I've convinced myself that this is a false positive.  The crazy 18,416
becomes 1,328 with freeListLib bypassed.  Which I think puts the address
in question in "event_que::evque[]".
While the dbEvent worker accesses "Q->evque[Q->getix]" without locking,
it does lock when incrementing "Q->getix" , which I think prevents a
concurrent write to that element of the array.
Possible data race during write of size 8 at 0x5197520 by thread #27
Locks held: 3, at addresses 0x51413A0 0x5143A60 0x5197A10
   at 0x48CA60A: db_queue_event_log (dbEvent.c:824)
   by 0x48CA732: db_post_events (dbEvent.c:892)
   by 0x48595EE: monitor (aoRecord.c:532)
   by 0x48595EE: process (aoRecord.c:232)
   by 0x48B2C6B: dbProcess (dbAccess.c:608)
   by 0x48B4BFF: dbPutField (dbAccess.c:1278)
   by 0x48CE9DD: dbChannel_put (db_access.c:923)
   by 0x48F6C9A: write_action (camessage.c:799)
   by 0x48F7727: camessage (camessage.c:2546)
   by 0x48F351F: camsgtask (camsgtask.c:116)
   by 0x495E094: start_routine (osdThread.c:439)
   by 0x483F876: mythread_wrapper (hg_intercepts.c:387)
   by 0x4F1EEA6: start_thread (pthread_create.c:477)
This conflicts with a previous read of size 8 by thread #21
Locks held: none
   at 0x48CA99D: event_read (dbEvent.c:999)
   by 0x48CA99D: event_task (dbEvent.c:1078)
   by 0x4CBADEE: clone (clone.S:95)
 Address 0x5197520 is 18,416 bytes inside a block of size 19,528 alloc'd
   at 0x48397CF: malloc (vg_replace_malloc.c:307)
   by 0x494DBE1: freeListMalloc (freeListLib.c:95)
   by 0x494DCE8: freeListCalloc (freeListLib.c:68)
   by 0x48C95B2: db_init_events (dbEvent.c:304)
   by 0x48D653C: dbContext::subscribe(epicsGuard<epicsMutex>&, dbChannel*, dbChannelIO&, unsigned int, unsigned long, unsigned int, cacStateNotify&, unsigned int*) (dbContext.cpp:221)
   by 0x48D7468: dbChannelIO::subscribe(epicsGuard<epicsMutex>&, unsigned int, unsigned long, unsigned int, cacStateNotify&, unsigned int*) (dbChannelIO.cpp:119)
   by 0x4EF7771: oldSubscription::oldSubscription(epicsGuard<epicsMutex>&, oldChannelNotify&, cacChannel&, unsigned int, unsigned long, unsigned int, void (*)(event_handler_args), void*, oldSubscription**) (oldSubscription.cpp:43)
   by 0x4EF7099: ca_create_subscription (oldChannelNotify.cpp:573)
   by 0x48D2BE8: dbCaTask (dbCa.c:1249)
 Block was alloc'd by thread #9
https://github.com/epics-base/epics-base/blob/3fadf4a26cfe33dcb9eb9e4620634e1d3a7b9763/modules/database/src/ioc/db/dbEvent.c#L824
https://github.com/epics-base/epics-base/blob/3fadf4a26cfe33dcb9eb9e4620634e1d3a7b9763/modules/database/src/ioc/db/dbEvent.c#L999
$ cat mr-regress.db record(ao,"testAo_0") {}
record(ao,"testAo_1") {}
record(ao,"testAo_2") {}
record(ao,"testAo_3") {}
record(ao,"testAo_4") {}
record(ao,"testAo_5") {}
record(ao,"testAo_6") {}
record(ao,"testAo_7") {}
record(ao,"testAo_8") {}
record(ao,"testAo_9") {}
record(ai,"testAi_0") {field(INP, "testAo_0 CP") }
record(ai,"testAi_1") {field(INP, "testAo_1 CP") }
record(ai,"testAi_2") {field(INP, "testAo_2 CP") }
record(ai,"testAi_3") {field(INP, "testAo_3 CP") }
record(ai,"testAi_4") {field(INP, "testAo_4 CP") }
record(ai,"testAi_5") {field(INP, "testAo_5 CP") }
record(ai,"testAi_6") {field(INP, "testAo_6 CP") }
record(ai,"testAi_7") {field(INP, "testAo_7 CP") }
record(ai,"testAi_8") {field(INP, "testAo_8 CP") }
record(ai,"testAi_9") {field(INP, "testAo_9 CP") }
$ valgrind --tool=helgrind ./bin/linux-x86_64/softIoc -d mr-regress.db
$ ./bin/linux-x86_64/caput testAo_0 1.0
$ ./bin/linux-x86_64/caput testAo_0 2.0
Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Torsten Bögershausen via Tech-talk
Prev: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Next: RE: Issue or misunderstanding with long string support Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Next: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
