1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
From: Michael Davidsaver via Tech-talk <[email protected]>
Date: Thu, 26 May 2022 15:22:39 -0700
On 5/26/22 14:48, Mark Rivers wrote:
Other ideas of how to debug it?
If we accept that the stack trace is correct, then memory corruption
at some earlier point seems likely.  It would be interesting to inspect
the stack of the faulting thread.  However, I don't know if this is
possible with your setup, and wouldn't be able to talk you through it
anyway.
At this point, maybe bite the bullet and go for git-bisect?  This
will likely take some time to work through, although perhaps less than
what has already been spent.
According to git 2.30.2 on my laptop, bisecting 7.0.5 through 7.0.6.1
would take 7 iterations assuming no skips (eg. build failures).
Begin with:
git bisect start R7.0.6.1 R7.0.5
This will update your checkout to a revision for testing.  Build
and run.  If if doesn't build, or the result is otherwise inconclusive,
then 'skip':
git bisect skip
If the problem appears:
git bisect bad
If the problem does not appear:
git bisect good
Each time the checkout will be updated to another revision.  Repeat
until complete.  Ideally this will narrow down to a single revision.
If there are skips, it will give a range of revisions (hopefully
not including a 3.15 merge commit...).
RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Prev: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules J. Lewis Muir via Tech-talk
Next: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
