Ø
At the top of freeListLib.c add:
Ø
#define EPICS_FREELIST_DEBUG
I did that and rebuilt base and synApps.
The error is the same:
ioc13lab2>
VME Bus Error accessing A16: 0x347e
machine check
Exception next instruction address: 0x0368cf38
Machine Status Register: 0x0008b032
Condition Register: 0x48000884
Task: 0x4441190 "CAS-event"
0x4441190 (CAS-event): task 0x4441190 has had a failure and has been stopped.
0x4441190 (CAS-event): The task has been terminated because it triggered an exception that raised the signal 10.
ioc13lab2> tt 0x4441190
0x0012489c vxTaskEntry +0x48 : epicsThreadEntry ()
0x036a8f18 epicsThreadEntry+0x80 : 0x036073f8 ()
0x036076d0 db_start_events+0x458: db_delete_field_log ()
0x03606be0 db_delete_field_log+0x54 : freeListFree ()
value = 0 = 0x0
Other ideas of how to debug it?
-----Original Message-----
Sent: Thursday, May 26, 2022 4:26 PM
To: Mark Rivers <[email protected]>
Cc: [email protected]
Subject: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
On 5/26/22 14:00, Mark Rivers wrote:
> It looks like freeListFree() is probably generating an access violation.
If so, this would almost certainly be a sign of a bug elsewhere.
(double free, free of stack, ...)
Bypassing freeListLib _might_ give some added insight, or perhaps change the fault in some way.
This will short circuit the free list code, to always call malloc() and free().
Or more specifically, callocMustSucceed(), you would find out if any allocation requests are failing.
https://github.com/epics-base/epics-base/blob/3fadf4a26cfe33dcb9eb9e4620634e1d3a7b9763/modules/libcom/src/freeList/freeListLib.c#L63-L65
