1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Till Straumann <till.straumann at psi.ch>, Michael Davidsaver <mdavidsaver at gmail.com>, Torsten Bögershausen <Torsten.Bogershausen at ess.eu>, Benjamin Franksen <benjamin.franksen at helmholtz-berlin.de>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 1 Jun 2022 23:17:00 +0000
I have now removed the return statements, so if the addresses are bad it will print an error message, and then still crash.
diff --git a/modules/database/src/ioc/db/dbEvent.c b/modules/database/src/ioc/db/dbEvent.c
index 9fcc1ee..d55b1eb 100644
--- a/modules/database/src/ioc/db/dbEvent.c
+++ b/modules/database/src/ioc/db/dbEvent.c
@@ -1198,8 +1198,16 @@ void db_event_flow_ctrl_mode_off (dbEventCtx ctx)
void db_delete_field_log (db_field_log *pfl)
     if (pfl) {
+        if ((pfl >= (db_field_log *)0x80000000) && (pfl <= (db_field_log *)0xBFFFFFFF)) {
+            printf("db_delete_field_log pfl is in A32 address space %p\n", pfl);
         /* Free field if reference type field log and dtor is set */
-        if (pfl->type == dbfl_type_ref && pfl->u.r.dtor) pfl->u.r.dtor(pfl);
+        if (pfl->type == dbfl_type_ref && pfl->u.r.dtor) {
+            if ((pfl->u.r.dtor >= (dbfl_freeFunc *)0x80000000) && (pfl->u.r.dtor <= (dbfl_freeFunc *)0xBFFFFFFF)) {
+                printf("db_delete_field_log pfl->u.r.dtor is in A32 address space %p\n", pfl->u.r.dtor);
+            pfl->u.r.dtor(pfl);
         /* Free the field log chunk */
         freeListFree(dbevFieldLogFreeList, pfl);
I ran this version with the address checks and it did not fail or print any error messages for 1650 seconds before I stopped it.
I then commented out the address check lines I added above.  I tested 3 times and it never ran for more than 10 seconds before it failed with either the A16 or A32 address errors and this task trace:
iocexample> tt 0x3596f20
0x0012489c vxTaskEntry  +0x48 : epicsThreadEntry ()
0x0333d704 epicsThreadEntry+0x80 : 0x0329ba28 ()
0x0329bd00 db_start_events+0x458: db_delete_field_log ()
0x0329b210 db_delete_field_log+0x54 : freeListFree ()
value = 0 = 0x0
That’s pretty convincing evidence that those address check lines have a dramatic effect on the behavior.
Sent: Wednesday, June 1, 2022 5:15 PM
To: Mark Rivers <rivers at cars.uchicago.edu>; Michael Davidsaver <mdavidsaver at gmail.com>; Torsten Bögershausen <Torsten.Bogershausen at ess.eu>; Benjamin Franksen <benjamin.franksen at helmholtz-berlin.de>
Cc: tech-talk at aps.anl.gov
Subject: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
On 6/1/22 23:50, Mark Rivers wrote:
I checked out R7.0.6.1 and made the following change to dbEvent.c  It checks whether pfl or pfl->u.r.dtor are in the VME A32 address space.  If they are it prints an error and returns.
index 9fcc1ee..3f757a4 100644
@@ -1198,8 +1198,18 @@ void db_event_flow_ctrl_mode_off (dbEventCtx ctx)
     if (pfl) {
+            return;
Note that if you return here then you won't actually dereference pfl->u.r.dtor after detecting that it was invalid.
This could explain that you don't crash.
+                return;
After making that change then one time when I started the IOC I got these messages right after iocInit, which is not when it usually fails.
iocexample> db_delete_field_log pfl->u.r.dtor is in A32 address space 0xbf490019
db_delete_C interp: unknown symbol name 'pfl'.
iocexample> field_log pfl->u.r.dtor is in A32 address space 0xbf490019
db_delete_field_C interp: unknown symbol name 'pfl'.
iocexample> log pfl->u.r.dtor is in A32 address space 0xbf518011
db_deletC interp: unknown symbol name 'pfl'.
iocexample> e_field_log pfl->u.r.dtor is in A32 address space 0xbf490019
db_delete_field_lC interp: unknown symbol name 'pfl'.
iocexample> og pfl->u.r.dtor is in A32 address space 0xbf240014
db_delete_field_log C interp: unknown symbol name 'pfl'.
iocexample> pfl->u.r.dtor is in A32 address space 0xbf3e001e
iocexample> e_field_log pfl->u.r.dtor is in A32 address space 0xbf3e001e
iocexample> og pfl->u.r.dtor is in A32 address space 0xbf518011
iocexample> pfl->u.r.dtor is in A32 address space 0xbf490019
iocexample> og pfl->u.r.dtor is in A32 address space 0xbf3e001e
db_delete_field_log C interp: unknopfl->.r.dtor is in A32 address space 0xbf490019
db_delete_feld_log pfl->u.r.dtor is in A32 address space 0xbf3e001e
db_delete_field_log pfl->u.r.dtor is in A32 address space 0xbf24014
db_delete_field_log pfl->u.r.dtor is in A32 address space0xbf3e001e
Note that those addresses are all 0xbfxxxxxx, which is exactly the address range of all the A32 bus errors I have ever seen.
However, adding those tests has actually made it fail less frequently if at all.   In fact, the only failure I have seen is that one time when I got the above messages right after iocInit.  Since then it has run for 1000 seconds without failing three times.
I then simply commented out those new lines and ran the test 3 times.  It failed in less than 10 seconds each time.  The failures were all in db_delete_field_log.
I then uncommented the address checks and ran it again.  It also ran for >1000 s without failing.
I guess there are 2 possibilities:
1.       The address checks change the timing, and a race error is avoided.  I wonder if there is a race that sets pfl->u.r.dtor in another thread, and now we are giving it time to be set correctly?
2.       The address checks change the memory layout, avoiding an uninitialized variable error.
I also made another interesting observation.  When I was initially adding the debugging above I was printing an error if pfl->u.r.dtor was in the A32 address space outside the check for pfl->type == dbfl_type_ref.  There were lots of messages, not every event but maybe 10 Hz out of ~400 events/s.  That means that the “uninitialized” value of pfl->u.r.dtor when pfl->type != dbfl_tpye_ref is often in the A32 address space.
-----Original Message-----
Sent: Wednesday, June 1, 2022 2:57 PM
To: Michael Davidsaver <mdavidsaver at gmail.com>; Mark Rivers <rivers at cars.uchicago.edu>; Torsten Bögershausen <Torsten.Bogershausen at ess.eu>; Benjamin Franksen <benjamin.franksen at helmholtz-berlin.de>
On 6/1/22 21:08, Michael Davidsaver wrote:
> On 6/1/22 11:20, Mark Rivers wrote:
>> Hi Till,
>> ØCould you please provide 'dbEvent.o' (from commit 85822f305) ?
>> I’m not sure what you mean.  Do you mean send the .o file itself, or
>> do a vxWorks disassembly of that function?
> Either.  The question is where this invalid address is coming from,
> and how it is being used.  I've wondered if this is a jump.  eg.
> if garbage address is being executed through "pfl->u.r.dtor(pfl)"
I have wondered the same thing. What chips away at this hypothesis is that Mark observed bus errors reporting addresses that can be read but not written. I don't see any obvious writes in the code leading up to the call to freeListFree().
>>     if (pfl) {
>> pfl->u.r.dtor(pfl);
>> Ø - check if the bus error is 'real', i.e., try to access the
>> reported VME address e.g., from the console
>>     (keeping in mind that A32 as seen from the CPU may be at an
>> offset - depending on OS/BSP).
>> This is the system VME memory map:
>> iocexample> sysVmeMapShow
>> VMEbus access from CPU:
>>          0x80000000 - 0xBFFFFFFF  =>  A32: 0x80000000 - 0xBFFFFFFF
>>          0xF0000000 - 0xF0FFFFFF  =>  A24:   0x000000 - 0xFFFFFF
>>          0xFBFF0000 - 0xFBFFFFFF  =>  A16:     0x0000 - 0xFFFF
>>          0xF2000000 - 0xF2FFFFFF  =>  CR/CSR:0x000000 - 0xFFFFFF
>> PCIbus access from VMEbus:
>>    A32:  0x80000000 - 0x9FFFFFFF  =>  RAM: 0x00000000 - 0x1FFFFFFF
>> value = 0 = 0x0
>> The A16 errors are all at addresses like this, i.e. address 0x34xx
>> [Fri May 27 14:05:24 2022] VME Bus Error accessing A16: 0x345e
>> [Fri May 27 14:20:20 2022] VME Bus Error accessing A16: 0x345e
>> [Fri May 27 15:49:10 2022] VME Bus Error accessing A16: 0x345e
>> [Fri May 27 15:49:57 2022] VME Bus Error accessing A16: 0x347e
>> [Fri May 27 16:15:55 2022] VME Bus Error accessing A16: 0x345e
>> [Fri May 27 16:39:39 2022] VME Bus Error accessing A16: 0x345e
>> [Tue May 31 17:59:31 2022] VME Bus Error accessing A16: 0x347e
>> [Tue May 31 22:09:43 2022] VME Bus Error accessing A16: 0x347e
>> The A32 VME bus errors are all at addresses like these,  i.e.
>> addresses 0xbfxxxxxx.
>> [Tue May 31 16:09:11 2022] VME Bus Error accessing A32: 0xbfe3332c
>> [Tue May 31 16:11:01 2022] VME Bus Error accessing A32: 0xbfdffff8
>> [Tue May 31 18:47:53 2022] VME Bus Error accessing A32: 0xbffb3330
>> [Tue May 31 18:47:54 2022] VME Bus Error accessing A32: 0xbfe99994
>> [Tue May 31 18:47:54 2022] VME Bus Error accessing A32: 0xbfe692d4
>> [Wed Jun  1 07:29:53 2022] VME Bus Error accessing A32: 0xbffcf67c
>> [Wed Jun  1 11:29:14 2022] VME Bus Error accessing A32: 0xbfa8c418
>> For these tests I only have a single VME card installed, other than
>> the MVME5100 CPU.  That card is a TVME200 IP carrier.  It is
>> configured with this command:
>> # The second carrier in our system is a TEWS TVME200
>> # The argument to ipacAddTVME200 is the values of the 6 switches on
>> the board
>> # In this case 34 = base address 3400
>> #               2 = interrupt mapping 4, 5, 2, 1, 4, 5, 2, 1
>> #               F = A32 address space, 8MB per slot, 32MB total
>> #              A2 = A2000000 base address in A32 space
>> ipacAddTVME200("342FA2")
>> This means that the card occupies 0x3400 to 0x37FF in the A16 address
>> space, each of the 4 IP slots used 0x100 bytes.  The IP330 module is
>> in slot 0, so it uses addresses 0x3400 – 0x34ff.
>> The VME bus errors are all at address 0x345e or 0x347e.  This means
>> they are in the mailbox register space of the IP330 card. Those
>> addresses should not generate a bus error on a read operation.  But
>> if it was a write operation then it should generate a bus error.
>> This is a memory dump of the A16 memory for the IP330.  Note that we
>> can indeed read address 0x345e and 0x347e.
>> iocexample> d 0xfbff3400
>> NOTE: memory values are displayed in hexadecimal.
>> 0xfbff3400:  2b02 4078 0021 0f00 0000 0000 0000 0000 *+.@x.!..........*
>> 0xfbff3410:  0000 0000 0000 0000 0000 0000 0000 0000 *................*
>> 0xfbff3420:  0000 0000 0000 0000 0000 0000 0000 0000 *................*
>> 0xfbff3430:  0000 0000 0000 0000 0000 0000 0000 0000 *................*
>> 0xfbff3440:  16b8 1701 1701 1700 171b 16fe 170b 16f9 *................*
>> 0xfbff3450:  1703 1702 16fa 16f4 170d 16ed 16fe 16e3 *................*
>> 0xfbff3460:  16b6 169c 16a7 1c2f 1c4a 1c2c 1c36 2138 *......./.J.,.6!8*
>> 0xfbff3470:  2db9 2dae 2d9a 2d86 330a 32e6 32ea 32cc *-.-.-.-.3.2.2.2.*
>> 0xfbff3480:  ff49 ff50 ff41 ff43 ffa3 ff11 ff00 ff00 *.I.P.A.C........*
>> 0xfbff3490:  ff00 ff00 ff0c ff5a ff00 ff00 ff00 ff00 *.......Z........*
>> 0xfbff34a0:  ff00 ff00 ff00 ff00 ff00 ff00 ff00 ff00 *................*
>> 0xfbff34b0:  ff00 ff00 ff00 ff00 ff00 ff00 ff00 ff00 *................*
>> 0xfbff34c0:  0054 0000 0054 0000 0054 0000 0054 0000 *.T...T...T...T..*
>> 0xfbff34d0:  0054 0000 0054 0000 0054 0000 0054 0000 *.T...T...T...T..*
>> 0xfbff34e0:  0054 0000 0054 0000 0054 0000 0054 0000 *.T...T...T...T..*
>> 0xfbff34f0:  0054 0000 0054 0000 0054 0000 0054 0000 *.T...T...T...T..*
>> value = 0 = 0x0
>> The A32 address errors are at 0xbfxxxxxx.  That is at the very top of
>> the A32 address space.  That is not where the TVME200 card is
>> located, it is at 0xA2000000.  Those addresses are not readable, and
>> do indeed generate an A32 bus error:
>> iocexample> *(0xbfe3332c)
>> machine check
>> Exception next instruction address: 0x001fe4f4
>> Machine Status Register: 0x0008b032
>> Condition Register: 0x88000244
>> 0x0012489c vxTaskEntry  +0x48 : 0x0020c554 ()
>> 0x0020c554 shellTask    +0x4a8: shellExec ()
>> 0x0020c020 shellExec    +0x11c: 0x00201a78 ()
>> 0x00201ca0 shellInterpCInit+0x640: shellInterpCparse ()
>> 0x00201384 shellInterpCparse+0xa3c: 0x001fe9f4 ()
>> 0x001fea24 shellInterpClex+0x1d6c: 0x001fe6dc ()
>> 0x001fe7a0 shellInterpClex+0x1ae8: 0x001fe490 ()
>> Shell task 'tShell0' restarted...
>> So the A16 bus errors are at a “valid” address, but perhaps a write
>> rather than a read is being done.  The A32 addresses cannot be read,
>> they do generate bus errors.
>> Mark
>> *From:* Till Straumann <till.straumann at psi.ch>
>> *Sent:* Wednesday, June 1, 2022 9:34 AM
>> *To:* Mark Rivers <rivers at cars.uchicago.edu>; Michael Davidsaver
>> *Cc:* tech-talk at aps.anl.gov
>> *Subject:* Re: Bus errors accessing VME with base 7.0.6.1 and latest
>> synApps modules
>> Hi Mark.
>> I'm sorry I missed the earlier post where you had indeed added the
>> 'ti' information.
>> Things I would try:
>>   - if this is the case then you may deal (as suggested earlier by
>> Michael, iirc) that the error is reported
>>     in a delayed fashion. I would try to insert some 'no-op' just
>> before the call to freeListFree() (make
>>     sure it is not optimized away) and see where the exception happens.
>>   - add a 'sanity-check' of 'pfl' and 'pfl->u.r.dtor' in
>> 'db_delete_field_log()' and report if any of these
>>     addresses is within a VME window.
>> I have seen similar things (late-reported bus error) but often we
>> would then find the fault address
>> in one of the registers (or a combination of some 'base' + 'offset'
>> in a couple of them) but I can't
>> see that in your register dump. It is still possible that it was in
>> one of the caller-saved registers
>> and got wiped when the call to 'freeListFree()' was set up.
>> Cheers
>> - T.
>> On 6/1/22 14:50, Mark Rivers via Tech-talk wrote:
>>     I agree that a debugger would be very helpful.  I don't have that
>> tool, but I think others at the APS do.  I'll find out when Andrew
>> returns next week.  Meanwhile git bisect can help point in the right
>> direction.
>>     I tested this commit 85822f3051d2236144bb46dc2c24b7e38143e531
>> with soft records overnight.  It ran for 32,000 seconds without
>> failing before I stopped it.
>>     The next commit, 56f05d722dee4b8ca2968b8bface2737a3a9b185, fails
>> in less than 10 seconds in each of 3 tests.
>>     I just tested with the IPAC hardware again with commit
>> 85822f3051d2236144bb46dc2c24b7e38143e531 (which does not fail with
>> soft records).  It failed after 960 seconds with this error:
>>     machine check
>>     Exception next instruction address: 0x03326a90
>>     Condition Register: 0x42000884
>>     Task: 0x3559330 "CAS-event"
>>     0x3559330 (CAS-event): task 0x3559330 has had a failure and has
>> been stopped.
>>     0x3559330 (CAS-event): The task has been terminated because it
>> triggered an exception that raised the signal 10.
>>     This is the task trace:
>>     iocexample> tt  0x3559330
>>     0x0334501c epicsThreadEntry+0x80 : 0x032a17f0 ()
>>     0x032a1acc db_start_events+0x450: db_delete_field_log ()
>>     0x032a0fe4 db_delete_field_log+0x54 : freeListFree ()
>>     value = 0 = 0x0
>>     This tells us pretty clearly that the failure as in freeListFree,
>> called by db_delete_field_log.  That has been a very common stack
>> trace for these errors.
>>     Till complained that vxWorks did not provide a register dump, but
>> that is not true, it is available with the “ti” command.  I had
>> included that in several previous messages. Here it is for this task.
>>     iocexample> ti  0x3559330
>>        NAME         ENTRY       TID    PRI   STATUS PC       SP
>> ERRNO  DELAY
>>     CAS-event   epicsThread>  3559330 133 STOP+I 3326a90
>> 3559240       0     0
>>     full task name : CAS-event
>>     task entry     : epicsThreadEntry
>>     process        : kernel
>>     options        : 0x1009001
>>     VX_SUPERVISOR_MODE  VX_DEALLOC_TCB      VX_FP_TASK
>> VX_DEALLOC_EXC_STACK
>>     STACK      BASE     END       SP      SIZE    HIGH   MARGIN
>>     execution  3559330  3556450  3559240   12000    2800    9200
>>     exception  2700210  26ff3a0             3696    1344    2352
>>     VxWorks Events
>>     Events Pended on    : Not Pended
>>     Received Events     : 0x0
>>     Options             : N/A
>>     r0         = 0x40000000   sp         = 0x03559240 r2         =
>> 0x002f1ac0
>>     r3         = 0x03492ce0   r4         = 0x0357bec8 r5         =
>> 0x00000001
>>     r6         = 0x00000001   r7         = 0x00000000 r8         =
>> 0xeefceefd
>>     r9         = 0x03326a90   r10        = 0x00000000 r11        =
>> 0x035591b0
>>     r12        = 0x20000884   r13        = 0x00321e60 r14        =
>> 0x033b6098
>>     r15        = 0x03373c64   r16        = 0x03289478 r17        =
>> 0x033424f0
>>     r18        = 0x03373bdc   r19        = 0x03373c1c r20        =
>> 0x032a0ff8
>>     r21        = 0x032a0f90   r22        = 0x00000000 r23        =
>> 0x00000001
>>     r24        = 0x033b609c   r25        = 0x03339340   r26        =
>> 0x033390e0
>>     r27        = 0x03443b60   r28        = 0x0357e748 r29        =
>> 0x03567d78
>>     r30        = 0x032dad44   r31        = 0x0357bec8 msr        =
>> 0x0008b032
>>     lr         = 0x032a0fe4   ctr        = 0x03326a90 pc         =
>> 0x03326a90
>>     cr         = 0x42000884   xer        = 0x00000000 pgTblPtr   =
>> 0x02310000
>>     scSrTblPtr = 0x0230fe74   srTblPtr   = 0x0230fe74
>>     fpcsr  =        0
>>     fr0    = -1.81018   fr1    =      NaN   fr2    =      NaN fr3
>> =      NaN
>>     fr4    =      NaN   fr5    =      NaN   fr6    =      NaN fr7
>> =      NaN
>>     fr8    =      NaN   fr9    =      NaN   fr10   =      NaN fr11
>> =      NaN
>>     fr12   =      NaN   fr13   =      NaN   fr14   =      NaN fr15
>> =      NaN
>>     fr16   =      NaN   fr17   =      NaN   fr18   =      NaN fr19
>> =      NaN
>>     fr20   =      NaN   fr21   =      NaN   fr22   =      NaN fr23
>> =      NaN
>>     fr24   =      NaN   fr25   =      NaN   fr26   =      NaN fr27
>> =      NaN
>>     fr28   =      NaN   fr29   =      NaN   fr30   =      NaN fr31
>> =      NaN
>>     machine checkvalue =
>>     Exception next instruction address: 0x003326a90
>>     Machine Status Register: 0x = 0008b032
>>     Condition Register: 0x420008840x
>>     0
>>     And here is the disassembly for freeListFree, where I have
>> highlighted in red the "next instruction" above.
>>                              freeListFree:
>>     0x3326a90  9421fff0    stwu        r1,-16(r1)
>>     0x3326a94  7c0802a6    mfspr       r0,LR
>>     0x3326a98  3d200334    lis         r9,0x334 # 820
>>     0x3326a9c  392990e0    addi        r9,r9,0x90e0 # -28448
>>     0x3326aa0  7d2903a6    mtspr       CTR,r9
>>     0x3326aa4  90010014    stw         r0,20(r1)
>>     0x3326aa8  93c10008    stw         r30,8(r1)
>>     0x3326aac  7c9e2378    or          r30,r4,r4
>>     0x3326ab0  93e1000c    stw         r31,12(r1)
>>     0x3326ab4  7c7f1b78    or          r31,r3,r3
>>     0x3326ab8  80630014    lwz         r3,20(r3)
>>     0x3326abc  4e800421    bcctrl      0x14,0
>>     0x3326ac0  2f830000    cmpi        crf7,0,r3,0x0 # 0
>>     0x3326ac4  41be002c    bc          0xd,30, 0x3326af0 # 0x03326af0
>>     0x3326ac8  3d200334    lis         r9,0x334 # 820
>>     0x3326acc  3c600338    lis         r3,0x338 # 824
>>     0x3326ad0  3ca00338    lis         r5,0x338 # 824
>>     0x3326ad4  392924f0    addi        r9,r9,0x24f0 # 9456
>>     0x3326ad8  386335a4    addi        r3,r3,0x35a4 # 13732
>>     0x3326adc  38a535c0    addi        r5,r5,0x35c0 # 13760
>>     0x3326ae0  7d2903a6    mtspr       CTR,r9
>>     0x3326ae4  3880008f    li          r4,0x8f # 143
>>     0x3326ae8  38c00000    li          r6,0x0 # 0
>>     0x3326aec  4e800421    bcctrl      0x14,0
>>     0x3326af0  813f0010    lwz         r9,16(r31)
>>     0x3326af4  801f0008    lwz         r0,8(r31)
>>     0x3326af8  39290001    addi        r9,r9,0x1 # 1
>>     0x3326afc  807f0014    lwz         r3,20(r31)
>>     0x3326b00  913f0010    stw         r9,16(r31)
>>     0x3326b04  3d200334    lis         r9,0x334 # 820
>>     0x3326b08  39299340    addi        r9,r9,0x9340 # -27840
>>     0x3326b0c  901e0000    stw         r0,0(r30)
>>     0x3326b10  7d2903a6    mtspr       CTR,r9
>>     0x3326b14  93df0008    stw         r30,8(r31)
>>     0x3326b18  4e800421    bcctrl      0x14,0
>>     0x3326b1c  80010014    lwz         r0,20(r1)
>>     0x3326b20  83c10008    lwz         r30,8(r1)
>>     0x3326b24  7c0803a6    mtspr       LR,r0
>>     0x3326b28  83e1000c    lwz         r31,12(r1)
>>     0x3326b2c  38210010    addi        r1,r1,0x10 # 16
>>     0x3326b30  4e800020    blr
>>     This is the source code for freeListFree in this tag of base.
>>     LIBCOM_API void epicsStdCall freeListFree(void *pvt,void*pmem)
>>          FREELISTPVT *pfl = pvt;
>>     #   ifdef EPICS_FREELIST_DEBUG
>>          memset ( pmem, 0xdd, pfl->size );
>>          free(pmem);
>>     #   else
>>          void        **ppnext;
>>          VALGRIND_MEMPOOL_FREE(pvt, pmem);
>>          VALGRIND_MEMPOOL_ALLOC(pvt, pmem, sizeof(void*));
>>          epicsMutexMustLock(pfl->lock);
>>          ppnext = pmem;
>>          *ppnext = pfl->head;
>>          pfl->head = pmem;
>>          pfl->nBlocksAvailable++;
>>          epicsMutexUnlock(pfl->lock);
>>     #   endif
>>     The last thing I will try is to git bisect from this commit
>> 85822f3051d2236144bb46dc2c24b7e38143e531 to R7.0.5 to see where the
>> hardware tests first begin to fail.
>>     Mark
>>     From: Michael Davidsaver <mdavidsaver at gmail.com>
>> <mailto:mdavidsaver at gmail.com>
>>     Sent: Wednesday, June 1, 2022 1:40 AM
>>     To: Torsten Bögershausen <Torsten.Bogershausen at ess.eu>
>> <mailto:Torsten.Bogershausen at ess.eu>; Mark Rivers
>> <rivers at cars.uchicago.edu> <mailto:rivers at cars.uchicago.edu>;
>> <mailto:benjamin.franksen at helmholtz-berlin.de>
>>     Cc: tech-talk at aps.anl.gov <mailto:tech-talk at aps.anl.gov>
>>     On 5/31/22 07:00, Torsten Bögershausen wrote:
>>      > Hej Mark,
>>      > So R7.0.5 is good, and
>> f9ea6a5bff695c5f88bb95dce38a3fd349738907 is bad ?
>>      > There are some "real" commits, and merges:
>>      > git log R7.0.5..f9ea6a5bff695c5f88bb95dce38a3fd349738907
>>      > Then it could make sense, to bisect between those 2?
>>      > Another question:
>>      > Coluld it make sense to run the SW (even more stripped may be)
>> under
>>      > Linux instead with valgrind ?
>>     An RTOS without a debugger is just about the worst situation I
>> can imagine to troubleshoot apparent memory corruption. (excepting
>> maybe having no console, or it being in orbit)
>>     I've made an attempt to run the database Mark describes with
>>     softIoc+valgrind, and a spam-y python script.  Valgrind doesn't
>>     flag any access violates.
>>     The threading checker ("valgrind --tool=helgrind") does flag a
>> possible race which might be relevant.  Or it might be a false
>> positive.  I don't feel that I understand dbEvent.c well enough to
>> say anything conclusive this late at night.
>>      > Possible data race during write of size 8 at 0x5197520 by
>> thread #27
>>      > Locks held: 3, at addresses 0x51413A0 0x5143A60 0x5197A10
>>      >    at 0x48CA60A: db_queue_event_log (dbEvent.c:824)
>>      >    by 0x48CA732: db_post_events (dbEvent.c:892)
>>      >    by 0x48595EE: monitor (aoRecord.c:532)
>>      >    by 0x48595EE: process (aoRecord.c:232)
>>      >    by 0x48B2C6B: dbProcess (dbAccess.c:608)
>>      >    by 0x48B4BFF: dbPutField (dbAccess.c:1278)
>>      >    by 0x48CE9DD: dbChannel_put (db_access.c:923)
>>      >    by 0x48F6C9A: write_action (camessage.c:799)
>>      >    by 0x48F7727: camessage (camessage.c:2546)
>>      >    by 0x48F351F: camsgtask (camsgtask.c:116)
>>      >    by 0x495E094: start_routine (osdThread.c:439)
>>      >    by 0x483F876: mythread_wrapper (hg_intercepts.c:387)
>>      >    by 0x4F1EEA6: start_thread (pthread_create.c:477)
>>      > This conflicts with a previous read of size 8 by thread #21 Locks
>>      > held: none
>>      >    at 0x48CA99D: event_read (dbEvent.c:999)
>>      >    by 0x48CA99D: event_task (dbEvent.c:1078)
>>      >    by 0x4CBADEE: clone (clone.S:95)
>>      >  Address 0x5197520 is 18,416 bytes inside a block of size
>> 19,528 alloc'd
>>      >    at 0x48397CF: malloc (vg_replace_malloc.c:307)
>>      >    by 0x494DBE1: freeListMalloc (freeListLib.c:95)
>>      >    by 0x494DCE8: freeListCalloc (freeListLib.c:68)
>>      >    by 0x48C95B2: db_init_events (dbEvent.c:304)
>>      >    by 0x48D653C: dbContext::subscribe(epicsGuard<epicsMutex>&,
>> dbChannel*, dbChannelIO&, unsigned int, unsigned long, unsigned int,
>> cacStateNotify&, unsigned int*) (dbContext.cpp:221)
>>      >    by 0x48D7468:
>> dbChannelIO::subscribe(epicsGuard<epicsMutex>&, unsigned int,
>> unsigned long, unsigned int, cacStateNotify&, unsigned int*)
>> (dbChannelIO.cpp:119)
>>      >    by 0x4EF7771:
>> oldSubscription::oldSubscription(epicsGuard<epicsMutex>&,
>> oldChannelNotify&, cacChannel&, unsigned int, unsigned long, unsigned
>> int, void (*)(event_handler_args), void*, oldSubscription**)
>> (oldSubscription.cpp:43)
>>      >    by 0x4EF7099: ca_create_subscription
>> (oldChannelNotify.cpp:573)
>>      >    by 0x48D2BE8: dbCaTask (dbCa.c:1249)
>>      >    by 0x4F1EEA6: start_thread (pthread_create.c:477) Block was
>>      > alloc'd by thread #9
>> https://github.com/epics-base/epics-base/blob/3fadf4a26cfe33dcb9eb9e4620634e1d3a7b9763/modules/database/src/ioc/db/dbEvent.c#L824
>> <https://github.com/epics-base/epics-base/blob/3fadf4a26cfe33dcb9eb9e4620634e1d3a7b9763/modules/database/src/ioc/db/dbEvent.c#L824>
>> https://github.com/epics-base/epics-base/blob/3fadf4a26cfe33dcb9eb9e4620634e1d3a7b9763/modules/database/src/ioc/db/dbEvent.c#L999
>> <https://github.com/epics-base/epics-base/blob/3fadf4a26cfe33dcb9eb9e4620634e1d3a7b9763/modules/database/src/ioc/db/dbEvent.c#L999>
>>      > $ cat mr-regress.db
>>      > record(ao,"testAo_0") {}
>>      > record(ao,"testAo_1") {}
>>      > record(ao,"testAo_2") {}
>>      > record(ao,"testAo_3") {}
>>      > record(ao,"testAo_4") {}
>>      > record(ao,"testAo_5") {}
>>      > record(ao,"testAo_6") {}
>>      > record(ao,"testAo_7") {}
>>      > record(ao,"testAo_8") {}
>>      > record(ao,"testAo_9") {}
>>      > record(ai,"testAi_0") {field(INP, "testAo_0 CP") }
>>      > record(ai,"testAi_1") {field(INP, "testAo_1 CP") }
>>      > record(ai,"testAi_2") {field(INP, "testAo_2 CP") }
>>      > record(ai,"testAi_3") {field(INP, "testAo_3 CP") }
>>      > record(ai,"testAi_4") {field(INP, "testAo_4 CP") }
>>      > record(ai,"testAi_5") {field(INP, "testAo_5 CP") }
>>      > record(ai,"testAi_6") {field(INP, "testAo_6 CP") }
>>      > record(ai,"testAi_7") {field(INP, "testAo_7 CP") }
>>      > record(ai,"testAi_8") {field(INP, "testAo_8 CP") }
>>      > record(ai,"testAi_9") {field(INP, "testAo_9 CP") }
>>      > $ valgrind --tool=helgrind ./bin/linux-x86_64/softIoc -d
>> mr-regress.db
>>      > $ ./bin/linux-x86_64/caput testAo_0 1.0
>>      > $ ./bin/linux-x86_64/caput testAo_0 2.0
Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Torsten Bögershausen via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Till Straumann via Tech-talk
Prev: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Next: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
