Subject: |
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules |
Jörn Dreyer via Tech-talk <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 02 Jun 2022 10:49:36 +0200 |
from the first message on, this problem to me looked like a array out of bound
problem somewhere. Did you consider running the IOC for a test using valgrind?
Or compile it with the electric fence library?
Jörn
Am Donnerstag, 2. Juni 2022, 06:06:53 CEST schrieb Mark Rivers via Tech-talk:
> We need to explain why adding 2 lines of code to examine the contents of pfl
> eliminates the failures completely.
> It’s like a new type of quantum computer - making an observation changes the
> outcome!
> Mark
> Sent from my iPhone
> > On Jun 1, 2022, at 10:24 PM, Michael Davidsaver <[email protected]>
> > wrote:
> > On 6/1/22 14:50, Mark Rivers wrote:
> >> I checked out R7.0.6.1 and made the following change to dbEvent.c It
> >> checks whether pfl or pfl->u.r.dtor are in the VME A32 address space.
> >> If they are it prints an error and returns.
> > So, these addresses appear in pfl->u.r.dtor or eg.
> > pfl->u.v.field.dbf_float
> > My question is then which part(s) of the db_field_log struct have
> > incorrect values?
(eg. "\xbf\x3e\x00\x1e" as float32 is -0.74)
> > One straightforward, though a bit tedious, think to do would be to print
> > a
> > dump of the contents of the db_field_log. eg. I'd be interested to know
> > if db_field_log::time appears valid.
> >> After making that change then one time when I started the IOC I got these
> >> messages right after iocInit, which is not when it usually fails.
> > This makes me wonder if these "addresses" are eg. somehow valid ADC
> > values,
which just happen to track through the VME window sometimes.
> > Though if you've only loading soft records, I don't see how this could
> > be.
> > Further, I still don't see how these values aren't appearing in the
> > register dump.
I don't think PPC has any instructions which do a double
> > indirection.
> > Another odd ball idea which occurs to me is that maybe the compiler is
> > mishandling
the db_field_log::type bit field. The dbEvent.o which you
> > send to Till and I has:
> >> 4c: 80 1f 00 00 lwz r0,0(r31)
> >> 50: 2f 80 00 00 cmpwi cr7,r0,0
> > If I read things correctly, I think this is meant to correspond to
> > 'pfl->u.r.type==dbfl_type_val==0", however it is testing the whole word,
> > and would
mis-trigger because 'pfl->u.r.ctx == dbfl_context_event == 1`
> > for a monitor update.
> > When I look at the result of a local RTEMS build, I think the
> > corresponding is:
> >> 8: 89 24 00 00 lbz r9,0(r4)
> >> c: 71 29 00 80 andi. r9,r9,128
> > Which is testing the high bit as it should.
> > For completeness. Disassembly of db_delete_field_log() from dbEvent.o.
> > Note that this is object code, with incomplete relocations.
> >> 00000034 <db_delete_field_log>:
> >> 34: 94 21 ff f0 stwu r1,-16(r1)
> >> 38: 7c 08 02 a6 mflr r0
> >> 3c: 93 e1 00 0c stw r31,12(r1)
> >> 40: 7c 7f 1b 79 mr. r31,r3
> >> 44: 90 01 00 14 stw r0,20(r1)
> >> 48: 41 82 00 40 beq 88 <db_delete_field_log+0x54>
> >> 54: 40 9c 00 18 bge cr7,6c <db_delete_field_log+0x38>
> >> 58: 80 1f 00 18 lwz r0,24(r31)
> >> 5c: 2f 80 00 00 cmpwi cr7,r0,0
> >> 60: 41 9e 00 0c beq cr7,6c <db_delete_field_log+0x38>
> >> 64: 7c 09 03 a6 mtctr r0
> >> 68: 4e 80 04 21 bctrl
> >> 6c: 3d 20 00 00 lis r9,0
> >> 70: 7f e4 fb 78 mr r4,r31
> >> 74: 80 69 00 00 lwz r3,0(r9)
> >> 78: 3d 20 00 00 lis r9,0
> >> 7c: 39 29 00 00 addi r9,r9,0
> >> 80: 7d 29 03 a6 mtctr r9
> >> 84: 4e 80 04 21 bctrl
> >> 88: 80 01 00 14 lwz r0,20(r1)
> >> 8c: 83 e1 00 0c lwz r31,12(r1)
> >> 90: 38 21 00 10 addi r1,r1,16
> >> 94: 7c 08 03 a6 mtlr r0
> >> 98: 4e 80 00 20 blr
> > From my local build for RTEMS-mvme3100
> >> void db_delete_field_log (db_field_log *pfl)
> >> if (pfl) {
> >> 0: 7c 64 1b 79 mr. r4,r3
> >> 4: 4d 82 00 20 beqlr
> >> /* Free field if reference type field log and dtor is set */
> >> if (pfl->type == dbfl_type_ref && pfl->u.r.dtor)
> >> pfl->u.r.dtor(pfl);
> >> 10: 40 82 00 10 bne 20 <db_delete_field_log+0x20>
> >> /* Free the field log chunk */
> >> freeListFree(dbevFieldLogFreeList, pfl);
> >> 14: 3d 20 00 00 lis r9,0
> >> 18: 80 69 00 00 lwz r3,0(r9)
> >> 1c: 48 00 00 00 b 1c <db_delete_field_log+0x1c>
> >> pfl->u.r.dtor(pfl);
> >> 20: 81 24 00 50 lwz r9,80(r4)
> >> 24: 2f 89 00 00 cmpwi cr7,r9,0
> >> 28: 41 be ff ec beq cr7,14 <db_delete_field_log+0x14>
> >> 2c: 94 21 ff f0 stwu r1,-16(r1)
> >> 30: 7c 08 02 a6 mflr r0
> >> pfl->u.r.dtor(pfl);
> >> 34: 7d 29 03 a6 mtctr r9
> >> 38: 90 01 00 14 stw r0,20(r1)
> >> 3c: 90 81 00 08 stw r4,8(r1)
> >> pfl->u.r.dtor(pfl);
> >> 40: 4e 80 04 21 bctrl
> >> 44: 80 01 00 14 lwz r0,20(r1)
> >> 48: 3d 20 00 00 lis r9,0
> >> pfl->u.r.dtor(pfl);
> >> 4c: 80 81 00 08 lwz r4,8(r1)
> >> 50: 80 69 00 00 lwz r3,0(r9)
> >> 54: 7c 08 03 a6 mtlr r0
> >> 58: 38 21 00 10 addi r1,r1,16
> >> 5c: 48 00 00 00 b 5c <db_delete_field_log+0x5c>
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Maren Purves via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Till Straumann via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
