Ray,
You can work around the initialization problem by adding a calcout
record to mirror the underlying motor's RBV:
record(calcout,"$(VM):rbvCalc")
field(DESC,"Mirror RBV")
field(CALC,"A")
field(INPA,"$(M1).RBV CP MS")
And then using the calcout in the virtual motor's RDBL field:
field(RDBL, "$(VM):rbvCalc")
Kevin
On 6/9/22 09:13, Gregory, Ray via Tech-talk wrote:
I am developing a Soft Channel motor to be a virtual motor that controls
two other motors. The virtual motor is essentially a copy of one of the
underlying motors and applies ‘adjustment’ moves to the other motor it
controls in accordance with a pre-specified alignment profile (using a
simple linear equation determined by calibration).
Most of this is working well. However, when the IOC starts, the virtual
motor often fails to retrieve its RBV value from the underling motor.
I’ve included the soft channel motor record below.
How do I fix this?
I am using EPICS base version 3.14.12.6. I am currently developing on my
VM with Simulated motors. I’m not sure what differences to expect when I
deploy this to an actual instrument.
So far I haven’t found a simple solution.
However, I have created horribly complicated solution that seems to
work: I created another do-nothing Soft Channel motor and make it part
of the virtual motor system, so now the overall virtual motor controls 3
motors, one of them being the do-nothing motor. Then, if the RBV value
was not set properly at launch time, I move this do-nothing motor. This
has the effect of sometimes properly setting the RBV of the main virtual
motor. If that doesn’t work, I try it again, and again, up to some
maximum number. I call this process ‘kicking’ the RBV.
It's a kludgy and nasty solution. I would very much appreciate knowing
how to fix this in some simple way.
Thank you,
Ray Gregory
Oak Ridge National Laboratory
- RE: [EXTERNAL] Re: RBV value for Soft Channel motor not always being set properly on IOC startup Gregory, Ray via Tech-talk
- RBV value for Soft Channel motor not always being set properly on IOC startup Gregory, Ray via Tech-talk
PyEpics: Cannot connect to DEVICE Thomas Feggeler via Tech-talk
Questions for epics 7 PVs: PV list with normative type Kim, Kukhee via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
