Hi Thomas,
Sorry for the trouble. Are you sure that it is necessary to set the EPICS_CA* environment variables in the Python script, or are those already set in the environment running your Python and PyCharm apps? What are these variables set to when running the command-line interface in a Terminal shell?
It should be that C:>. caget PVNAME and
C:> python -c "import epics ; print(epics.caget('PVNAME'))" give the same result - the Python interpreter should inherit whatever EPICS_CA ADDR settings you have for the shell. If that works, then try:
C:> printenv
and grep (either with Posix commands or by hand) for EPICS_CA_ADDR.
--Matt On Thu, Jun 9, 2022 at 10:28 AM Thomas Feggeler via Tech-talk < [email protected]> wrote: Dear colleagues,
We have a new computer installation (Windows 10) with epics 7.0.4, python 3.6.4. When I try to connect with caget() directly over the command line to access a device, e.g.
Caget XXXX:XXXX:firmwarebuilddate
It immediately works.
When using pyepics over pycharm, or the python interpreter, the message „cannot connect to DEVICE“ is given out.
The Windows path variables are set, EPICS_CA_ADDR_LIST is set and imported into the pycharm environment.
In both pycharm and python console if I do the following:
import epics
import os
from epics import PV, caget, caput, cainfo
os.environ['EPICS_CA_ADDR_LIST'] = 'XXX.XXX.XXX.XXX'
os.environ['EPICS_CA_AUTO_ADDR_LIST'] = 'NO'
print(caget('XXXX:XXXX:firmwarebuilddate'))
The same error occurs.
I’d kindly ask for your help.
Thank you
Kind wishes
Thomas
- PyEpics: Cannot connect to DEVICE Thomas Feggeler via Tech-talk
RE: Removing battery/crystal from MVME 5100 Stone, Eric D via Tech-talk
Re: Removing battery/crystal from MVME 5100 Maren Purves via Tech-talk
<2022>
2025
2026
RE: PyEpics: Cannot connect to DEVICE Mark Rivers via Tech-talk
Questions for epics 7 PVs: PV list with normative type Kim, Kukhee via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
