1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: measComp R4-0 available
Date: Fri, 10 Jun 2022 19:49:38 +0000
Folks,
measComp R4-0 is available.  This is from the release notes:
  - Changed the Linux support from using the low-level drivers from Warren Jasper (https://github.com/wjasper/Linux_Drivers)
    to using the "UL for Linux" library (uldaq) from Measurement Computing.
    This is an open-source library available on Github (https://github.com/mccdaq/uldaq).
    The Linux Universal Library API is similar to the Windows Universal Library API,
    but the functions have different names and different syntax.
  - On Linux the Measurement Computing "UL for Linux" library must be locally installed.
    The instructions for doing this are in the README.md file.
  - The higher-level drivers, drvMultiFunction.cpp and drvUSCTR.cpp were changed to make
    different function calls for Linux and Windows.
  - For USB devices the UNIQUE_ID (serial number) in the startup script must now be
    8 characters long.  This means adding a leading 0 for seven-digit serial numbers.
  - Added open thermocouple detect (OTD) support for models that support it (e.g. USB-2408).
  - Added analog input Rate record to control the sampling rate for models that support it (e.g. USB-2408).
  - Added DRVH and DRVL limits for NumPoints in the waveform digitizer and waveform generator.
  - Added DwellActual records to report the actual dwell time for the waveform digitizer and waveform generator.
https://github.com/epics-modules/meascomp
Prev: Re: PVStructure vs Structure Michael Davidsaver via Tech-talk
Next: ADEiger R3-4 released Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: RE: StreamDevice with a REST API Freddie Akeroyd - STFC UKRI via Tech-talk
