Folks,
ADEiger R3-4 is now available. This is from the release notes:
* Added a new Continuous mode choice for TriggerMode. In Continuous mode acquisition continues
indefinitely once it is started, until the Acquire record is set to 0 (Done).
If NumImages=1 and NumTriggers=1 then acquisition is rather slow, about 1 Hz,
because of the overhead in the detector server. However, if NumImages or NumTriggers
is greater than 1 then it will collect NumImages*NumTriggers images quickly, and then have
about a 1 second delay before collecting the next set.
* Fixed a problem where the AcquireTime, AcquirePeriod, and ThresholdEnergy would not have the
previous values when the IOC restarted. This is because these can be set automatically when
other parameters are changed, and so the readback values did not match the drive values.
Added the asyn:READBACK info tag to these records so the drive values update when the
readbacks are changed. The correct values are now saved with autosave.
https://github.com/areaDetector/ADEiger
https://areadetector.github.io/master/ADEiger/eiger.html
