1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Github and travis question
From: Pete Jemian via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 13 Jun 2022 15:44:01 -0500
This SO post seems relevant: https://stackoverflow.com/questions/13566200/how-can-i-install-from-a-git-subdirectory-with-pip/50930840#comment42223717_19516714
Can you change to git+https://... ?
On 6/13/2022 3:40 PM, Mark Rivers via Tech-talk wrote:
The .travis.yml file in areaDetector contains these lines:
    - pip install git+git://github.com/drdoctr/[email protected]
    - pip install git+git://github.com/michaeljones/[email protected]
    - pip install git+git://github.com/return42/linuxdoc.git
This was working OK, but recently the travis builds have been failing with this error:
$ pip install git+git://github.com/drdoctr/[email protected]
Collecting git+git://github.com/drdoctr/[email protected]
   Cloning git://github.com/drdoctr/doctr.git (to revision 1.7.4) to /tmp/pip-req-build-7r_gfskr
   Running command git clone --filter=blob:none -q git://github.com/drdoctr/doctr.git /tmp/pip-req-build-7r_gfskr
   fatal: unable to connect to github.com:
   github.com[0: 140.82.113.3]: errno=Connection timed out
I don’t understand what the syntax “git+git://github.com/drdoctr/[email protected]” means.  I have used https://github.com <https://github.com> for https access and [email protected] <mailto:[email protected]> for ssh access, but I have not seen git://github.com outside of this travis script. Can someone explain?
I found that if I replace git:// with https:// it works.
    - pip install git+https://github.com/drdoctr/[email protected]
    - pip install git+https://github.com/michaeljones/[email protected]
    - pip install git+https://github.com/return42/linuxdoc.git
What the difference between git:// and https:// is, and is OK to make this change?
Pete R. Jemian, Ph.D.                 <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source,    Argonne National Laboratory
Argonne, IL  60439                    630 - 252 - 3189
      Education is the one thing for which people
         are willing to pay yet not receive.
Github and travis question Mark Rivers via Tech-talk
Prev: Github and travis question Mark Rivers via Tech-talk
Next: Re: Github and travis question Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
