This is a longish explanation what
" pip install git+git://github.com/drdoctr/[email protected]"
means, and why
" pip install git+https://github.com/drdoctr/[email protected]"
is better.
The line
tells pip to use Git as a version control system (and not svn, hg, bzr).
That is the "git" before the '+'
The second "git" is the protocol:
https://git-scm.com/book/en/v2/Git-on-the-Server-The-Protocols
Both https and ssh protocols use encryption, but the git protocol does not.
And neither does http (without the s) use encryption.
The http has been used a long time (even when talking to git servers),
but now most web servers are configured to use https only.
In that sense, http has been deprecated.
The protocol that does not use encryption either is the git protocol.
And using the git protocol is getting more and more deprecated.
For github we can read here:
<https://github.blog/changelog/2022-03-15-removed-unencrypted-git-protocol-and-certain-ssh-keys/>
Back to pip:
https://pip.pypa.io/en/stable/cli/pip_install/
indicates that
should be used (and that is what is what you do now, Mark)
/Torsten
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Reply-To: Mark Rivers <[email protected]>
Date: Monday, 13 June 2022 at 22:40
To: "[email protected]" <[email protected]>
Subject: Github and travis question
The .travis.yml file in areaDetector contains these lines:
- pip install git+git://github.com/drdoctr/[email protected]
- pip install git+git://github.com/michaeljones/[email protected]
- pip install git+git://github.com/return42/linuxdoc.git
This was working OK, but recently the travis builds have been failing with this error:
$ pip install git+git://github.com/drdoctr/[email protected]
Collecting git+git://github.com/drdoctr/[email protected]
Cloning git://github.com/drdoctr/doctr.git (to revision 1.7.4) to /tmp/pip-req-build-7r_gfskr
Running command git clone --filter=blob:none -q git://github.com/drdoctr/doctr.git /tmp/pip-req-build-7r_gfskr
fatal: unable to connect to github.com:
github.com[0: 140.82.113.3]: errno=Connection timed out
I don’t understand what the syntax “git+git://github.com/drdoctr/[email protected]” means. I have used https://github.com for https access and mailto:[email protected] for ssh access, but I have not seen git://github.com outside of this travis script. Can someone explain?
I found that if I replace git:// with https:// it works.
- pip install git+https://github.com/drdoctr/[email protected]
- pip install git+https://github.com/michaeljones/[email protected]
- pip install git+https://github.com/return42/linuxdoc.git
What the difference between git:// and https:// is, and is OK to make this change?
- Github and travis question Mark Rivers via Tech-talk
Re: Github and travis question Pete Jemian via Tech-talk
Open positions in Controls @ PSI Celcer Tine (PSI) via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
