1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: win10 and base7.0.6.1
To: tech-talk <[email protected]>
Date: Tue, 14 Jun 2022 16:01:27 +0800 (CST)
     I was try to use epics on Win10(64).
base 7.0.6.1;
Strawberry Perl (64-bit) 5.32.1.1-64bit;
Win10 family    Microsoft Windows [Version 10.0.19044.1706]
Visual Studio 2022
set _epics_host_arch=windows-x64
windows.bat
set _auto=yes
set _auto_path_reset=%_auto%
set _auto_path_append=%_auto%
set _path_new=C:\Windows\System32;C:\Windows;C:\Windows\System32\wbem
set _strawberry_perl_home=C:\Strawberry
set _visual_studio_home=D:\Program Files\VS2019\
set _epics_base=D:\epics\base-7.0.6.1
set "PATH=%PATH%;%_strawberry_perl_home%\c\bin"
set "PATH=%PATH%;%_strawberry_perl_home%\perl\site\bin"
set "PATH=%PATH%;%_strawberry_perl_home%\perl\bin"
call "%_visual_studio_home%\VC\Auxiliary\Build\vcvarsall.bat" x64
Output of gmake after windows.bat and gmake:
gmake[3]: Entering directory 'D:/epics/base-7.0.6.1/modules/libcom/src'
C:/Strawberry/c/bin/gmake -C O.windows-x64 -f ../Makefile TOP=../../../.. \
    T_A=windows-x64 install
gmake[4]: Entering directory 'D:/epics/base-7.0.6.1/modules/libcom/src/O.windows-x64'
"Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h"
perl -CSD D:/epics/base-7.0.6.1/bin/windows-x64/expandVars.pl -t ../../../.. -D INSTALL_BIN=D:/epics/base-7.0.6.1/bin/windows-x64  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="21"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="0"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="0"  ../libComVersion.h@ libComVersion.h
"Installing generated generic include file ../../../../include/libComVersion.h"
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         -c ../flex/ccl.c
process_begin: CreateProcess(NULL, cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include -c ../flex/ccl.c, ...) failed.
make (e=2): System could not find the file.
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         -c ../yacc/closure.c
process_begin: CreateProcess(NULL, cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include -c ../yacc/closure.c, ...) failed.
gmake[4]: *** No rule to make target 'ccl.obj', needed by 'e_flex.exe'.  Stop.
gmake[4]: Leaving directory 'D:/epics/base-7.0.6.1/modules/libcom/src/O.windows-x64'
gmake[3]: *** [../../../configure/RULES_ARCHS:58: install.windows-x64] Error 2
gmake[3]: Leaving directory 'D:/epics/base-7.0.6.1/modules/libcom/src'
gmake[2]: *** [../../configure/RULES_DIRS:85: src.install] Error 2
gmake[2]: Leaving directory 'D:/epics/base-7.0.6.1/modules/libcom'
gmake[1]: *** [../configure/RULES_DIRS:85: libcom.install] Error 2
gmake[1]: Leaving directory 'D:/epics/base-7.0.6.1/modules'
gmake: *** [configure/RULES_DIRS:85: modules.install] Error 2
Liang
RE: win10 and base7.0.6.1 Mark Rivers via Tech-talk
Re: win10 and base7.0.6.1 Ralph Lange via Tech-talk
Prev: Open positions in Controls @ PSI Celcer Tine (PSI) via Tech-talk
Next: RE: win10 and base7.0.6.1 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
