Hi Simon, we bind all our IOCs to localhost on each host and then use a CA gateway on the same machine to control any required access from the main network to loopback
Freddie
Hello Ralph -
That might work on at least one of our hosts, but some of them will also want to be able to be accessed from outside, unfortunately.
S.
Is it possible to set up an access security file to allow only CA/PVA requests from the same host as the IOC? One option of course is to use asSetSubstitutions
and some variable, but it seems like there should be a more intrinsic way of doing this.
I have attempted using the name “localhost”, asCheckClientIP set to 1, even using 127.0.0.1 as a member of the host access group, but none of these seemed to
work.
My two main questions:
Is there a better or more canonical way of doing this?
Perhaps more importantly--particularly if we have to use environment variables and substitutions--is there some danger or pitfall about this that we should be careful about?
If the only aim is to restrict access to clients on the local machine (e.g. for test environments to not affect other hosts), I would bind the IOC's server to localhost and not use AS.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
- Allowing localhost in access control files Simon Rose via Tech-talk
- Re: Allowing localhost in access control files Ralph Lange via Tech-talk
- Re: Allowing localhost in access control files Simon Rose via Tech-talk
Re: win10 and base7.0.6.1 Ralph Lange via Tech-talk
Re: Problem with NTP configuration Matt Rippa via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
