Subject: |
Re: Allowing localhost in access control files |
Ralph Lange via Tech-talk <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Wed, 15 Jun 2022 12:38:29 +0200 |
That might work on at least one of our hosts, but some of them will also want to be able to be accessed from outside, unfortunately.
If you want those outside clients to talk directly to the IOC (and not through a Gateway as per Freddie's setup), the allowed connections from the same machine would probably not be coming through loopback, but also through the external network.
I would start the IOC, connect a client from the same host, use "casr" on the IOC to check which address that client is listed as, and use that address in the AS file. This will be different for each host, obviously.
Cheers, ~Ralph
- Allowing localhost in access control files Simon Rose via Tech-talk
- Re: Allowing localhost in access control files Ralph Lange via Tech-talk
- Re: Allowing localhost in access control files Simon Rose via Tech-talk
Re: dbpf error - Operation not permitted at IOC initialization Eric Norum via Tech-talk
Re: dbpf error - Operation not permitted at IOC initialization Bernhard Kuner via Tech-talk
<2022>
2025
2026
RE: Allowing localhost in access control files Freddie Akeroyd - STFC UKRI via Tech-talk
Problem with NTP configuration Francisco Ramos via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
