> -----Original Messages-----
> From: "Heinz Junkes" <[email protected]>
> Sent Time: 2022-06-20 22:33:32 (Monday)
> To: [email protected]
> Cc: "[email protected]" <[email protected]>
> Subject: Re: Some Questions With RTEMS 5 in MVME2502
> I am wondering myself…
> Did you build RTEMS with legacy stack or with rtems-libbsd?
I build RTEMS with rtems-libbsd.
> To get the shell input to work, you could replace in
> modules/libcom/RTEMS/posix/rtems_config.c
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> with
> #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
I replaced the #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER with #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER in modules/libcom/RTEMS/posix/rtems_config.c and modules/libcom/RTEMS/score/rtems_config.c. Both files need to be modified.
> Viele Grüße
> Heinz
Maybe there is something I'm not configuring correctly.
Thanks for your help.
chengsn
> > On 20. Jun 2022, at 11:26, [email protected] wrote:
> > Compile after uncommenting, I get this error:
> > /home/chengsn/RTEMS/MVME2500/RTEMS/rtems-5/lib/gcc/powerpc-rtems5/7.5.0/../../../../powerpc-rtems5/bin/ld: /home/chengsn/RTEMS/MVME2500/EPICS/base-7.0.6.1/lib/RTEMS-qoriq_e500/librtemsCom.a(rtems_init.o): in function `POSIX_Init':
> > /home/chengsn/RTEMS/MVME2500/EPICS/base-7.0.6.1/modules/libcom/RTEMS/O.RTEMS-qoriq_e500/../posix/rtems_init.c:1115: undefined reference to `rtems_telnetd_initialize'
> > collect2: error: ld returned 1 exit status
> > ../../../../../configure/RULES_BUILD:230: recipe for target 'softIoc' failed
> > Maybe I should ld the libtelnetd.a. What should I do?
> >> Sent Time: 2022-06-20 16:57:49 (Monday)
> >> You're right, that needs to be commented out. Unfortunately, I had overlooked it.
> >> Viele Grüße
> >> Heinz
> >>> On 20. Jun 2022, at 10:51, [email protected] wrote:
> >>> Thanks for your help!
> >>> When I try to connect to 10.1.201.13, I get "telnet: connect to address 10.1.201.13: Connection refused error". I changed another computer and tried again, still the same. But I can access the PV on 10.1.201.13 on the pc, either via caget or pvget.
> >>> Maybe the rtems_telnetd_initialize() in rtems_init() should be run?
> >>> Some code in the rtems_init.c:1112,
> >>> #if __RTEMS_MAJOR__>4
> >>> // if telnetd is requested ...
> >>> // printf(" Will try to start telnetd with prio %d ...\n", rtems_telnetd_config.priority);
> >>> // result = rtems_telnetd_initialize();
> >>> // printf (" telnetd initialized with result %d\n", result);
> >>> #endif
> >>> Thanks!
> >>> chengsn
> >>>> Sent Time: 2022-06-17 16:04:46 (Friday)
> >>>> hi chengsn,
> >>>> That doesn't look so bad. Unfortunately, I don't have an MVME2500 at the moment on which I can reproduce the whole thing.
> >>>> I have built telnet access into the rtems_init:
> >>>> #ifndef RTEMS_LEGACY_STACK
> >>>> // setup own ntp-client to get time
> >>>> /telnet
> >>>> char line[LINE_SIZE];
> >>>> int fid[3], save_fid[3];
> >>>> printf("info: pty dev name = %s\n", name);
> >>>> save_fid[1] = dup2(1,1);
> >>>> fid[1] = dup2( fileno(stdout), 1);
> >>>> if (fid[1] == -1 ) printf("Can't dup stdout\n");
> >>>> save_fid[2] = dup2(2,2);
> >>>> fid[2] = dup2( fileno(stderr), 2);
> >>>> if (fid[2] == -1 ) printf("Can't dup stderr\n");
> >>>> const char *prompt = "tIocSh> ";
> >>>> while (1) {
> >>>> fputs(prompt, stdout);
> >>>> fflush(stdout);
> >>>> /* telnet close not detected ??? tbd */
> >>>> if (fgets(line, LINE_SIZE, stdin) == NULL) {
> >>>> dup2(save_fid[1],1);
> >>>> dup2(save_fid[2],2);
> >>>> return;
> >>>> if (line[strlen(line)-1] == '\n') line[strlen(line)-1] = 0;
> >>>> if (!strncmp( line, "bye",3)) {
> >>>> printf( "%s", "Will end session\n");
> >>>> return;
> >>>> iocshCmd(line);
> >>>> You could try connecting to the system with "telnet 10.1.201.13" and you
> >>>> should then be in an EPICS shell.
> >>>> To exit, type "bye" (not CTRL-], otherwise the shell is blocked).
> >>>> Viele Grüße
> >>>> Heinz Junkes
> >>>> Experience directly varies with equipment ruined.
> >>>>> On 16. Jun 2022, at 12:14, chengsn via Tech-talk <[email protected]> wrote:
> >>>>> Sorry, I got something wrong, the EPICS 7 version I used was downloaded from github, and just now I re-tryed the base-7.0.6.1 version: $ wget https://epics.anl.gov/download/base/base-7.0.6.1.tar.gz.
> >>>>> Then, I ran the exampleApp :
> >>>>> ***** Until now no NTP support in RTEMS 5 with rtems-libbsd *****
> >>>>> ***** Ask ntp server once... *****
> >>>>> time from ntp : 06/16/22 09:59:35.000001019 UTC
> >>>>> ***** Setting up file system *****
> >>>>> ***** Initializing NFS *****
> >>>>> nfsMount("10.1.201.31", "/tftpboot", "/tftpboot")
> >>>>> Mount 10.1.201.31:/tftpboot on /tftpboot
> >>>>> check for time registered , C++ initialization ...
> >>>>> ***** Preparing EPICS application *****
> >>>>> chdir("/tftpboot/mv2500/")
> >>>>> ***** Starting EPICS application *****
> >>>>> #< envPaths
> >>>>> ## Register all support components
> >>>>> dbLoadDatabase("dbd/test.dbd")
> >>>>> test_registerRecordDeviceDriver(pdbbase)
> >>>>> ## Load record instances
> >>>>> dbLoadTemplate("db/user.substitutions")
> >>>>> dbLoadRecords("db/testVersion.db", "user=chengsn")
> >>>>> dbLoadRecords("db/dbSubExample.db", "user=chengsn")
> >>>>> #var mySubDebug 1
> >>>>> #traceIocInit
> >>>>> iocInit
> >>>>> Starting iocInit
> >>>>> ## EPICS R7.0.6.1
> >>>>> ## Rev. 2022-06-16T17:52+0800
> >>>>> iocRun: All initialization complete
> >>>>> ## Start any sequence programs
> >>>>> #seq(sncExample, "user=chengsn")
> >>>>> ***** Primary Network interface : tsec0 *****
> >>>>> all out ---> interface = tsec2
> >>>>> all out ---> reason = IPV4LL
> >>>>> all out ---> pid = 1
> >>>>> all out ---> ifmetric = 203
> >>>>> all out ---> ifwireless = 0
> >>>>> all out ---> ifflags = 4294936643
> >>>>> all out ---> ifmtu = 1500
> >>>>> all out ---> interface_order = tsec0 tsec2 tsec1
> >>>>> all out ---> if_up = true
> >>>>> all out ---> if_down = false
> >>>>> all out ---> new_ip_address = 169.254.57.184
> >>>>> all out ---> new_subnet_cidr = 16
> >>>>> all out ---> new_network_number = 169.254.0.0
> >>>>> all out ---> new_subnet_mask = 255.255.0.0
> >>>>> all out ---> new_broadcast_address = 169.254.255.255
> >>>>> all out ---> interface = tsec0
> >>>>> all out ---> reason = RENEW
> >>>>> all out ---> ifmetric = 201
> >>>>> all out ---> old_ip_address = 10.1.201.13
> >>>>> all out ---> old_subnet_cidr = 24
> >>>>> all out ---> old_broadcast_address = 10.1.201.255
> >>>>> all out ---> old_network_number = 10.1.201.0
> >>>>> all out ---> old_server_name = 10.1.201.31
> >>>>> all out ---> old_subnet_mask = 255.255.255.0
> >>>>> all out ---> old_routers = 10.1.201.1
> >>>>> all out ---> old_dhcp_lease_time = 600
> >>>>> all out ---> old_dhcp_message_type = 5
> >>>>> all out ---> old_dhcp_server_identifier = 10.1.201.31
> >>>>> all out ---> old_dhcp_renewal_time = 300
> >>>>> all out ---> old_dhcp_rebinding_time = 525
> >>>>> all out ---> new_ip_address = 10.1.201.13
> >>>>> all out ---> new_subnet_cidr = 24
> >>>>> all out ---> new_broadcast_address = 10.1.201.255
> >>>>> all out ---> new_network_number = 10.1.201.0
> >>>>> all out ---> new_server_name = 10.1.201.31
> >>>>> all out ---> new_subnet_mask = 255.255.255.0
> >>>>> all out ---> new_routers = 10.1.201.1
> >>>>> all out ---> new_dhcp_lease_time = 600
> >>>>> all out ---> new_dhcp_message_type = 5
> >>>>> all out ---> new_dhcp_server_identifier = 10.1.201.31
> >>>>> all out ---> new_dhcp_renewal_time = 300
> >>>>> all out ---> new_dhcp_rebinding_time = 525
> >>>>> But I cannot input anything in the shell.
> >>>>> Is this normal?
> >>>>> -----原始邮件-----
> >>>>> 发件人:[email protected]
> >>>>> 发送时间:2022-06-16 17:14:33 (星期四)
> >>>>> 收件人: "[email protected]" <[email protected]>
> >>>>> 抄送:
> >>>>> 主题: Some Questions With RTEMS 5 in MVME2502
> >>>>> Hello All,
> >>>>> I followed the steps at EPICS with RTEMS, compiled RTEMS 5, and ran an example hello on MVME2502. The dtb file was generated from the linux source file: $ dtc -I dts -O dtb linux/arch/powerpc/boot/dts/fsl/mvme2500.dts -o mvme2500.dtb
> >>>>> If I didn't change the macro definition #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER to #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER in the file test.c, the OUTPUT is:
> >>>>> Bytes transferred = 12331 (302b hex)
> >>>>> WARNING: adjusting available memory to 30000000
> >>>>> ## Booting kernel from Legacy Image at 01000000 ...
> >>>>> Image Name: hello
> >>>>> Created: 2022-06-09 15:06:14 UTC
> >>>>> Image Type: PowerPC Linux Kernel Image (gzip compressed)
> >>>>> Data Size: 51612 Bytes = 50.4 KiB
> >>>>> Load Address: 00004000
> >>>>> Entry Point: 00004000
> >>>>> Verifying Checksum ... OK
> >>>>> ## Flattened Device Tree blob at 00c00000
> >>>>> Booting using the fdt blob at 0xc00000
> >>>>> Uncompressing Kernel Image ... OK
> >>>>> ft_fixup_l2cache: FDT_ERR_NOTFOUND
> >>>>> ?H?@?LR???r????I?C?=GC?c?
> >>>>> Then, I compiled EPICS base 7.0.6.1, made a EPICS exampleApp test, ran the image file bin/RTEMS-qoriq_e500/test.img. The OUTPUT is:
> >>>>> Image Name: test
> >>>>> Created: 2022-06-08 16:51:21 UTC
> >>>>> Data Size: 2734725 Bytes = 2.6 MiB
> >>>>> ?C???)???G?}[k???C8V?o?????????????k???J?G&k)?J?gb!?CruB??????g?s ?C1H?cbjR?C?b???c??=?????????C1H?cbjR?C?b???c??=???????? ?C1H?cbjR?C?b???c??=?????????C1H?cbjR?C?b???c??=???????? ?C1H?cbjR?C?b???c??=????????1b?R?W?jR?C?b???c?????gb
> >>>>> So, I had to change the macro definition #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER to #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER in the file base/modules/libcom/RTEMS/posix/rtems_config.c.
> >>>>> Did I do something wrong?
> >>>>> After recompiling EPICS and making the exampleApp, the IOC started to get the ip through DHCP. I set some file paths in the rtems_init.c file, but there was some other information after the IOC initialization was completed:
> >>>>> diff --git a/modules/libcom/RTEMS/posix/rtems_init.c b/modules/libcom/RTEMS/posix/rtems_init.c
> >>>>> index 403cd0785..d7886b6ab 100644
> >>>>> --- a/modules/libcom/RTEMS/posix/rtems_init.c
> >>>>> +++ b/modules/libcom/RTEMS/posix/rtems_init.c
> >>>>> @@ -97,10 +97,10 @@ epicsEventId dhcpDone;
> >>>>> * may provide by dhcp/bootp
> >>>>> * or environments from the "BIOS" like u-boot, motboot etc.
> >>>>> -char rtemsInit_NTP_server_ip[16] = "";
> >>>>> -char bootp_server_name_init[128] = "[email protected]:/epics";
> >>>>> -char bootp_boot_file_name_init[128] = "/epics/myExample/bin/RTEMS-beatnik/myExample.boot";
> >>>>> -char bootp_cmdline_init[128] = "/epics/myExample/iocBoot/iocmyExample/st.cmd";
> >>>>> +char rtemsInit_NTP_server_ip[16] = "10.1.201.31";
> >>>>> +char bootp_server_name_init[128] = "10.1.201.31:/tftpboot";
> >>>>> +char bootp_boot_file_name_init[128] = "/tftpboot/mv2500/bin/RTEMS-qoriq_e500/test.img";
> >>>>> +char bootp_cmdline_init[128] = "/tftpboot/mv2500/iocBoot/ioctest/st.cmd";
> >>>>> struct in_addr rtems_bsdnet_bootp_server_address;
> >>>>> /* TODO check rtems_bsdnet_bootp_cmdline */
> >>>>> some OUTPUT:
> >>>>> MVME2500=> run epicsTest
> >>>>> Speed: 1000, full duplex
> >>>>> Using eTSEC1 device
> >>>>> TFTP from server 10.1.201.31; our IP address is 10.1.201.125
> >>>>> Filename 'mv2500/bin/RTEMS-qoriq_e500/test.img'.
> >>>>> Load address: 0x1000000
> >>>>> Loading: #################################################################
> >>>>> done
> >>>>> Bytes transferred = 1997059 (1e7903 hex)
> >>>>> Using eTSEC1 device
> >>>>> Filename 'mvme2500.dtb'.
> >>>>> Load address: 0xc00000
> >>>>> Loading: #
> >>>>> done
> >>>>> Image Name: test
> >>>>> Created: 2022-06-08 14:23:06 UTC
> >>>>> Data Size: 1996995 Bytes = 1.9 MiB
> >>>>> WARNING: OS Clock time was read before being set.
> >>>>> Using 1990-01-02 00:00:00.000000 UTC
> >>>>> initConsole --- Info ---
> >>>>> stdin: fileno: 0, ttyname: /dev/console
> >>>>> stdout: fileno: 1, ttyname: /dev/console
> >>>>> stderr: fileno: 2, ttyname: /dev/console
> >>>>> tcgetattr failed: Not a character device
> >>>>> time set to : 04/14/14 07:30:06.000000839 UTC
> >>>>> Startup.
> >>>>> epicsThreadSetPriority called by non epics thread
> >>>>> ***** RTEMS Version: rtems-5.0.0 (PowerPC/Generic (E500/float-gprs/SPE)/qoriq_e500) *****
> >>>>> ***** Initializing network (libbsd, dhcpcd) *****
> >>>>> nexus0: <RTEMS Nexus device>
> >>>>> ofwbus0: <Open Firmware Device Tree> on nexus0
> >>>>> -------------- IFCONFIG -----------------
> >>>>> tsec0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
> >>>>> options=8000b<RXCSUM,TXCSUM,VLAN_MTU,LINKSTATE>
> >>>>> ether ec:9e:cd:13:47:66
> >>>>> inet6 fe80::ee9e:cdff:fe13:4766%tsec0 prefixlen 64 scopeid 0x1
> >>>>> inet 10.1.201.13 netmask 0xffffff00 broadcast 10.1.201.255
> >>>>> nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
> >>>>> media: Ethernet autoselect (1000baseT <full-duplex>)
> >>>>> status: active
> >>>>> tsec1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
> >>>>> ether ec:9e:cd:13:47:67
> >>>>> inet6 fe80::ee9e:cdff:fe13:4767%tsec1 prefixlen 64 scopeid 0x2
> >>>>> media: Ethernet autoselect (none)
> >>>>> status: no carrier
> >>>>> tsec2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
> >>>>> options=b<RXCSUM,TXCSUM,VLAN_MTU>
> >>>>> ether ec:9e:cd:13:47:68
> >>>>> inet6 fe80::ee9e:cdff:fe13:4768%tsec2 prefixlen 64 scopeid 0x3
> >>>>> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
> >>>>> options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
> >>>>> inet 127.0.0.1 netmask 0xffffff00
> >>>>> inet6 ::1 prefixlen 128
> >>>>> inet6 fe80::1%lo0 prefixlen 64 scopeid 0x4
> >>>>> groups: lo
> >>>>> -------------- NETSTAT ------------------
> >>>>> Routing tables
> >>>>> Internet:
> >>>>> Destination Gateway Flags Netif Expire
> >>>>> default 10.1.201.1 UGS tsec0
> >>>>> 10.1.201.0/24 link#1 U tsec0
> >>>>> 10.1.201.13 link#1 UHS lo0
> >>>>> 127.0.0.1 link#4 UH lo0
> >>>>> Internet6:
> >>>>> ::1 link#4 UH lo0
> >>>>> fe80::%tsec0/64 link#1 U tsec0
> >>>>> fe80::ee9e:cdff:fe13:4766%tsec0 link#1 UHS lo0
> >>>>> fe80::%tsec1/64 link#2 U tsec1
> >>>>> fe80::ee9e:cdff:fe13:4767%tsec1 link#2 UHS lo0
> >>>>> fe80::%tsec2/64 link#3 U tsec2
> >>>>> fe80::ee9e:cdff:fe13:4768%tsec2 link#3 UHS lo0
> >>>>> fe80::%lo0/64 link#4 U lo0
> >>>>> fe80::1%lo0 link#4 UHS lo0
> >>>>> debug: tsec0: sending ARP announce (2 of 2)
> >>>>> debug: tsec2: sending DISCOVER (xid 0xa096e1f), next in %0.1f seconds
> >>>>> time from ntp : 06/15/22 06:51:49.000000839 UTC
> >>>>> chdir("/tftpboot/mv2500/iocBoot/ioctest/")
> >>>>> #< envPaths
> >>>>> dbLoadDatabase("../../dbd/test.dbd")
> >>>>> #dbLoadTemplate("db/user.substitutions")
> >>>>> dbLoadRecords("../../db/testVersion.db", "user=chengsn")
> >>>>> dbLoadRecords("../../db/circle.db", "user=chengsn")
> >>>>> dbLoadRecords("../../db/dbSubExample.db", "user=chengsn")
> >>>>> #var mySubDebug 1
> >>>>> #traceIocInit
> >>>>> iocInit
> >>>>> Starting iocInit
> >>>>> ## EPICS R7.0.6.2-DEV
> >>>>> ## Rev. R7.0.6.1-103-g3fadf4a26cfe33dcb9eb-dirty
> >>>>> RTEMShost> tsec2: sending DISCOVER (xid 0xa096e1f), next in 31.1 secondstimed outallowing 8 seconds for IPv4LL timeouttsec2: probing for an IPv4LL addresstsec2: checking for 169.254.92.20tsec2: sending ARP probe (1 of 3), next in 1.6 secondstsec2: sending ARP probe (2 of 3), next in 1.7 secondstsec2: sending ARP probe (3 of 3), next in 2.0 secondstsec2: using IPv4LL address 169.254.92.20tsec2: adding IP address 169.254.92.20/16tsec0: adding host route to 10.1.201.13 via 127.0.0.1tsec0: ipv4_addroute: mtsec0: adding route to 10.1.201.0/24tsec0: ipv4_addroute: mtsec2: adding host route to 169.254.92.20 via 127.0.0.1tsec2: ipv4_addroute: mtsec2: adding route to 169.254.0.0/16tsec2: ipv4_addroute: mtsec2: writing lease `/var/db/dhcpcd-tsec2.lease'tsec2: executing `ioc boot' IPV4LL
> >>>>> dhcpcd ---> 'interface=tsec2'
> >>>>> 'interface' = 'tsec2'
> >>>>> dhcpcd ---> 'reason=IPV4LL'
> >>>>> 'reason' = 'IPV4LL'
> >>>>> dhcpcd ---> 'pid=1'
> >>>>> dhcpcd ---> 'ifmetric=203'
> >>>>> dhcpcd ---> 'ifwireless=0'
> >>>>> dhcpcd ---> 'ifflags=4294936643'
> >>>>> dhcpcd ---> 'ifmtu=1500'
> >>>>> dhcpcd ---> 'interface_order=tsec0 tsec2 tsec1'
> >>>>> dhcpcd ---> 'if_up=true'
> >>>>> dhcpcd ---> 'if_down=false'
> >>>>> dhcpcd ---> 'new_ip_address=169.254.92.20'
> >>>>> dhcpcd ---> 'new_subnet_cidr=16'
> >>>>> dhcpcd ---> 'new_network_number=169.254.0.0'
> >>>>> dhcpcd ---> 'new_subnet_mask=255.255.0.0'
> >>>>> dhcpcd ---> 'new_broadcast_address=169.254.255.255'
> >>>>> tsec2: sending ARP announce (1 of 2), next in 2.0 secondstimed outtsec2: sending ARP announce (2 of 2)tsec2: soliciting a DHCP leasetsec2: sending DISCOVER (xid 0x614c417a), next in 3.6 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 7.3 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 15.5 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 32.5 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.6 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.5 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.6 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.9 secondstsec0: renewing lease of 10.1.201.13tsec0: rebind in 225 seconds, expire in 300 secondstsec0: sending REQUEST (xid 0x504868fd), next in 4.5 secondstsec0: acknowledged 10.1.201.13 from 10.1.201.31 `10.1.201.31'tsec0: leased 10.1.201.13 for 600 secondstsec0: renew in 300 seconds, rebind in 525 secondstsec0: IP address 10.1.201.13/24 already existstsec0: adding host route to 10.1.201.13 via 127.0.0.1tsec0: ipv4_addroute: mtsec0: adding route to 10.1.201.0/24tsec0: ipv4_addroute: mtsec2: adding host route to 169.254.92.20 via 127.0.0.1tsec2: ipv4_addroute: mtsec2: adding route to 169.254.0.0/16tsec2: ipv4_addroute: mtsec0: writing lease `/var/db/dhcpcd-tsec0.lease'tsec0: executing `ioc boot' RENEW
> >>>>> Then, the IOC will keep restarting...
> >>>>> What should I do to get the IOC working properly?
> >>>>> Best regards,
> >>>>> chengsn
- Re: Some Questions With RTEMS 5 in MVME2502 Heinz Junkes via Tech-talk
- Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
- Re: Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
- Re: Re: Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
MATLAB and LabCA Larregui, Julian via Tech-talk
Re: MATLAB and LabCA Till Straumann via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
