Hello,
Currently trying to install LabCA 3.8 with MATLAB 2022a.
I've set my my paths in the Release file:
MATLABDIR=C:\EPICS_MATLAB\MATLAB\R2022a
and
MATLIB_SUBDIR=C:\EPICS_MATLAB\MATLAB\R2022a\extern\lib\win64\mingw64
When I run make I get the following error:
EPICS/epics-base/include/compiler/gcc -I/home/larregui1-linux/EPICS/epics-base/include/os/Linux -I/home/larregui1-linux/EPICS/epics-base/include -I../../ezca -IC:\EPICS_MATLAB\MATLAB\R2022a/extern/include -c gitstring.c
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DMATLAB_APP -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -Werror-implicit-function-declaration -g -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc
-I../../include/os/Linux -I../../include -I/home/larregui1-linux/EPICS/epics-base/include/compiler/gcc -I/home/larregui1-linux/EPICS/epics-base/include/os/Linux -I/home/larregui1-linux/EPICS/epics-base/include -I../../ezca -IC:\EPICS_MATLAB\MATLAB\R2022a/extern/include
-c ../mglue.c
make[2]: *** No rule to make target '../../lib/linux-x86_64/libmx.a', needed by 'libmezcaglue.so.0'. Stop.
make[2]: Leaving directory '/home/larregui1-linux/EPICS/support/epics-labca-master/glue/O.linux-x86_64'
/home/larregui1-linux/EPICS/epics-base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/larregui1-linux/EPICS/support/epics-labca-master/glue'
/home/larregui1-linux/EPICS/epics-base/configure/RULES_DIRS:85: recipe for target 'glue.install' failed
make: *** [glue.install] Error 2
I wanted to know if anyone had this same issue. Is this from incorrectly configuring the Release file? Anything I can try to get around this?
I guess I can also try installing 2020b or 2020a versions of MATLAB and see if that works.
Thank you for your time,
