1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: [EXTERNAL] Configuration Parameters with more than 16 states
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Florian Feldbauer <florian at ep1.ruhr-uni-bochum.de>
Date: Tue, 21 Jun 2022 14:00:28 +0000
With base 7+, the PV Access server can be included in the IOC in addition to the CA server.
In Phoebus/CSS, you can then simply use   pva://NameOfThePV for your combobox to read/write that one via PVA, which has no 16-state limitation.
-Kay
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Florian Feldbauer via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, June 21, 2022 9:53 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Configuration Parameters with more than 16 states
Hey all,
usually, when I have a device with a configuration parameter where I can
select predefined values I use mbbi/o records for it.
Now I have a device where some of such configuration parameters have 20
possible values, so one mbbo does not work anymore (only 16 states)
Is there some elegant way to handle this with epics which also allows
this parameter to be easily displayed (e.g. with a combobox in Phoebus/CSS)?
I'm using base 7.0.6.1.
Thanks in advance,
   Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Configuration Parameters with more than 16 states Florian Feldbauer via Tech-talk
Prev: Configuration Parameters with more than 16 states Florian Feldbauer via Tech-talk
Next: Re: [EXTERNAL] phoebus table widget not updating its PV Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Std and Base duplicate definition of record type João Pedro Burle Ishida via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
