Ø
Is that a new standardizing pattern, creating and using the xxxSuport.dbd instead of xxx.dbd?
I don’t think it is new, but it is the way most synApps modules are written. This is the list of all files with that name pattern in my synApps tree:
corvette:~/devel>ls -l *-*/dbd/*Support.dbd
-r--r--r-- 1 epics domain users 26 May 29 08:20 alive-1-4/dbd/aliveSupport.dbd
-r--r--r-- 1 epics domain users 534 May 29 08:20 autosave-5-10-2/dbd/asSupport.dbd
-rwxrwxr-x 1 epics domain users 181 Jun 18 18:15 busy-1-7-3/dbd/busySupport.dbd
-rwxrwxr-x 1 epics domain users 1492 Jun 18 18:12 calc-3-7-4/dbd/calcSupport.dbd
-r--r--r-- 1 epics domain users 181 Mar 12 2021 camac-2-7-3/dbd/camacSupport.dbd
-r--r--r-- 1 epics domain users 242 Mar 12 2021 camac-2-7-3/dbd/devCamacSupport.dbd
-r--r--r-- 1 epics domain users 30 May 29 08:20 dac128V-2-10-1/dbd/dac128VSupport.dbd
-r--r--r-- 1 epics domain users 120 May 29 08:24 dante-1-1/dbd/mcaDanteSupport.dbd
-r--r--r-- 1 epics domain users 317 May 29 08:21 delaygen-1-2-3/dbd/delaygenSupport.dbd
-r--r--r-- 1 epics domain users 36 May 29 08:21 delaygen-1-2-3/dbd/nigpibSupport.dbd
-r--r--r-- 1 epics domain users 102 May 29 08:24 dxp-6-0/dbd/dxpSupport.dbd
-r--r--r-- 1 epics domain users 102 May 29 08:24 dxpSITORO-1-2/dbd/dxpSITOROSupport.dbd
-r--r--r-- 1 epics domain users 2628 May 29 08:20 ip-2-21-1/dbd/ipSupport.dbd
-r--r--r-- 1 epics domain users 1373 May 29 08:20 ip-2-21-1/dbd/ipVXSupport.dbd
-r--r--r-- 1 epics domain users 26 May 29 08:20 ip330-2-10/dbd/ip330Support.dbd
-r--r--r-- 1 epics domain users 28 May 29 08:20 ipUnidig-2-12/dbd/ipUnidigSupport.dbd
-r--r--r-- 1 epics domain users 681 May 29 08:20 lua-3-0-2/dbd/luaSupport.dbd
-r--r--r-- 1 epics domain users 200 Jun 20 14:55 mca-7-9/dbd/SIS38XXSupport.dbd
-r--r--r-- 1 epics domain users 91 Jun 20 13:16 mca-7-9/dbd/mcaAmptekSupport.dbd
-r--r--r-- 1 epics domain users 100 Jun 20 14:55 mca-7-9/dbd/mcaBrukerQM100Support.dbd
-r--r--r-- 1 epics domain users 226 Jun 20 14:55 mca-7-9/dbd/mcaCanberraSupport.dbd
-r--r--r-- 1 epics domain users 91 Jun 20 14:55 mca-7-9/dbd/mcaRontecSupport.dbd
-r--r--r-- 1 epics domain users 298 Jun 20 14:55 mca-7-9/dbd/mcaSupport.dbd
-r--r--r-- 1 epics domain users 31 May 29 08:21 measComp-4-0/dbd/measCompDemoSupport.dbd
-r--r--r-- 1 epics domain users 96 May 29 08:21 measComp-4-0/dbd/measCompSupport.dbd
-r--r--r-- 1 epics domain users 69 May 29 08:20 modbus-3-2/dbd/modbusSupport.dbd
-r--r--r-- 1 epics domain users 28 May 29 08:21 motor-7-2-2/dbd/ACRMotorSupport.dbd
-r--r--r-- 1 epics domain users 52 May 29 08:21 motor-7-2-2/dbd/AMCISupport.dbd
-r--r--r-- 1 epics domain users 54 May 29 08:21 motor-7-2-2/dbd/ANF2Support.dbd
-r--r--r-- 1 epics domain users 54 May 29 08:21 motor-7-2-2/dbd/ANG1Support.dbd
-r--r--r-- 1 epics domain users 29 May 29 08:21 motor-7-2-2/dbd/LC400MotorSupport.dbd
-r--r--r-- 1 epics domain users 73 May 29 08:21 motor-7-2-2/dbd/MicronixSupport.dbd
-r--r--r-- 1 epics domain users 52 May 29 08:21 motor-7-2-2/dbd/NPointMotorSupport.dbd
-r--r--r-- 1 epics domain users 126 May 29 08:21 motor-7-2-2/dbd/PI_GCS2Support.dbd
-r--r--r-- 1 epics domain users 52 May 29 08:21 motor-7-2-2/dbd/ParkerSupport.dbd
-r--r--r-- 1 epics domain users 131 May 29 08:21 motor-7-2-2/dbd/motorSimSupport.dbd
-r--r--r-- 1 epics domain users 248 May 29 08:20 motor-7-2-2/dbd/motorSupport.dbd
-r--r--r-- 1 epics domain users 91 May 29 08:21 motor-7-2-2/dbd/omsAsynMAXnetSupport.dbd
-r--r--r-- 1 epics domain users 221 May 29 08:21 motor-7-2-2/dbd/omsAsynSupport.dbd
-r--r--r-- 1 epics domain users 27 May 29 08:21 motor-7-2-2/dbd/phytronSupport.dbd
-r--r--r-- 1 epics domain users 496 May 29 08:20 optics-2-13-5/dbd/opticsSupport.dbd
-r--r--r-- 1 epics domain users 367 May 29 08:20 scaler-4-0/dbd/scalerSupport.dbd
-r--r--r-- 1 epics domain users 233 May 29 08:20 softGlue-2-8-3/dbd/softGlueSupport.dbd
-r--r--r-- 1 epics domain users 1472 May 29 08:20 softGlueZynq-2-0-4/dbd/softGlueZynqSupport.dbd
-r--r--r-- 1 epics domain users 33 May 29 08:20 sscan-2-11-5/dbd/sscanProgressSupport.dbd
-r--r--r-- 1 epics domain users 945 May 29 08:20 sscan-2-11-5/dbd/sscanSupport.dbd
-r--r--r-- 1 epics domain users 732 May 29 08:20 std-4-0/dbd/stdSupport.dbd
-r--r--r-- 1 epics domain users 261 May 29 08:20 std-4-0/dbd/stdVXSupport.dbd
-r--r--r-- 1 epics domain users 471996 May 29 08:21 tpmac-3-11dls5/dbd/pmac-ethSupport.dbd
-r--r--r-- 1 epics domain users 581 May 29 08:20 vac-1-9-1/dbd/vacSupport.dbd
-r--r--r-- 1 epics domain users 188 May 29 08:20 vme-2-9-4/dbd/vmeSupport.dbd
-r--r--r-- 1 epics domain users 2970 May 29 08:20 vme-2-9-4/dbd/vmeVXSupport.dbd
-r--r--r-- 1 epics domain users 30 May 29 08:24 xspress3-2-6/dbd/xspress3Support.dbd
Thank you Mark that has resolved the std.dbd issues.
Because I found a tech-talk from March that had the same issue with the modbus and modbusSupport.
I suspect your application is confusing std.dbd and stdSupport.dbd.
std.dbd is a complete dbd file used for booting the test IOCs in the std module. It contains the definitions from base.dbd.
stdSupport.dbd is the dbd file that you should be including in your application dbd file.
On Behalf Of João Pedro Burle Ishida via Tech-talk
Sent: Tuesday, June 21, 2022 12:16 PM
To: [email protected]
Subject: Std and Base duplicate definition of record type
Hello,
I'm compiling an IOC which uses std-R3-6, asyn-R4-36,calc-R3-7-3, StreamDevice-2-8-9, autosave-R5-10, seq-2-2-6 and base R3.15.6 to talk to an equipment.
The IOC was compiling until the implementation of
doAfterIocInit() of std.dbd, and use the seqSoftIoc.dbd . Now when I compile appears these errors
perl -CSD /usr/local/epics-nfs/base/R3.15.6/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/usr/local/epics-nfs/base/R3.15.6/dbd -I/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/asyn-R4-36/dbd
-I/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/calc-R3-7-3/dbd -I/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/StreamDevice-2-8-9/dbd -I/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/autosave-R5-10/dbd -I/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/std-R3-6/dbd
-I/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/seq-2-2-6/dbd -o cryostream800.dbd base.dbd std.dbd asyn.dbd calc.dbd drvAsynIPPort.dbd stream.dbd seqSoftIoc.dbd sncExample.dbd
dbdExpand.pl: Duplicate definition of record type 'sub'
Context: recordtype(sub) in file '/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/std-R3-6/dbd/std.dbd'
while reading 'std.dbd' to create 'cryostream800.dbd'
dbdExpand.pl: Duplicate definition of record type 'mbbi'
Context: recordtype(mbbi) in file '/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/seq-2-2-6/dbd/seqSoftIoc.dbd' in recordtype(sub) in file '/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/std-R3-6/dbd/std.dbd'
while reading 'seqSoftIoc.dbd' to create 'cryostream800.dbd'
I need these modules to implement some functions, but I can't figure out if the
std.dbd has base.dbd included or how to fix it.
Thanks in advance and good morning,
João P. B. Ishida
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes
de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before
copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
