1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: AreaDetector Teledyne driver question
Date: Wed, 22 Jun 2022 19:18:49 -0700
Yes but there’s a possibility the frame arrives when I’m not in that function.
The polling loop would need to:
getIntegerParam(ADAcquire, &acquire)
If (acquire ==0) break
GevWaitForFrame()
And if the frame arrives when I’m not waiting I need to know to send another trigger.
On Wed, Jun 22, 2022 at 6:46 PM Mark Rivers <[email protected]> wrote:
Hi David,
Can you call GevWaitForFrame(timeout) with a short timeout?  If so then can’t that thread just poll with a short timeout. It should abort the polling loop if any of the following happens:
- It receives the frame OK
- It receives an abort signal
- It has been polling for significantly longer than the exposure time.
Sent from my iPhone
On Jun 22, 2022, at 7:04 PM, David Vine via Tech-talk <[email protected]> wrote:
Hi all,
I wrote a driver for the Teledyne Shadobox 6k flat panel detector.
The API has a function called GevWaitForFrame(timeout) which must be being executed by the driver when a frame arrives from the camera or the frame will be missed. Are there any examples of a driver that has a similar API?
The problem is that it creates a race condition so if I execute the code sequentially:
send trigger
GevWaitForFrame(1 second)
It's possible for the frame to arrive before I'm "waiting" for it. Right now I have two threads that receive epicsEventSignal - one to send the trigger and one to wait.
That works ok but since I can't abort the GevWaitForFrame the driver gets out of sync for longer exposures. Eg I have a 5 second exposure so I set a 7 second timeout but then abort after 1 second my wait thread is stuck for 6 seconds.
I haven't had a camera API work like this before so any examples would be really helpful.
David
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Re: AreaDetector Teledyne driver question David Vine via Tech-talk
Re: AreaDetector Teledyne driver question Mark Rivers via Tech-talk
Prev: Re: areaDetector build errors Mark Rivers via Tech-talk
Next: Re: AreaDetector Teledyne driver question David Vine via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: AreaDetector Teledyne driver question Mark Rivers via Tech-talk
