1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: areaDetector build errors
To: Jong Woo Kim <[email protected]>
Date: Thu, 23 Jun 2022 01:51:16 +0000
Hi Jong Woo,
Did you follow the installation instructions here:
In particular did you edit RELEASE_PRODS.local to set the path to autosave, calc, etc., (assuming that you want to use them) as documented here:
Sent from my iPhone
On Jun 22, 2022, at 6:19 PM, Jong Woo Kim via Tech-talk <[email protected]> wrote:
Hello,
I just cloned areaDetector, ADCore, ADSupport, ADEiger.
I am using base-3.15.6 and asyn4-38
When I was building areaDetector, I encountered the following errors.
Any ideas?
_____________________________________________________________________
perl -CSD /usr/local/EPICS_NEW/base-3.15.6/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -I/usr/local/EPICS_NEW/synApps_6_1/support/asyn4-38/dbd -I/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/dbd -I/usr/local/EPICS_NEW/base-3.15.6/dbd -o eigerDetectorApp.dbd eigerDetectorSupport.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd NDFileNetCDF.dbd NDFileTIFF.dbd NDFileNexus.dbd NDFileHDF5.dbd NDFileJPEG.dbd asyn.dbd asSupport.dbd busySupport.dbd calcSupport.dbd devIocStats.dbd sscanSupport.dbd
dbdExpand.pl: Can't find file 'asSupport.dbd'
  while reading 'asSupport.dbd' to create 'eigerDetectorApp.dbd'
  Your Makefile may need this dependency rule:
    $(COMMON_DIR)/eigerDetectorApp.dbd: $(COMMON_DIR)/asSupport.dbd
dbdExpand.pl: Can't find file 'busySupport.dbd'
  while reading 'busySupport.dbd' to create 'eigerDetectorApp.dbd'
    $(COMMON_DIR)/eigerDetectorApp.dbd: $(COMMON_DIR)/busySupport.dbd
dbdExpand.pl: Can't find file 'calcSupport.dbd'
  while reading 'calcSupport.dbd' to create 'eigerDetectorApp.dbd'
    $(COMMON_DIR)/eigerDetectorApp.dbd: $(COMMON_DIR)/calcSupport.dbd
dbdExpand.pl: Can't find file 'devIocStats.dbd'
  while reading 'devIocStats.dbd' to create 'eigerDetectorApp.dbd'
    $(COMMON_DIR)/eigerDetectorApp.dbd: $(COMMON_DIR)/devIocStats.dbd
dbdExpand.pl: Can't find file 'sscanSupport.dbd'
  while reading 'sscanSupport.dbd' to create 'eigerDetectorApp.dbd'
    $(COMMON_DIR)/eigerDetectorApp.dbd: $(COMMON_DIR)/sscanSupport.dbd
dbdExpand.pl: Exiting due to errors
make[6]: *** [../O.Common/eigerDetectorApp.dbd] Error 2
make[6]: Leaving directory `/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC/eigerApp/src/O.linux-x86_64'
make[5]: *** [install.linux-x86_64] Error 2
make[5]: Leaving directory `/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC/eigerApp/src'
make[4]: *** [src.install] Error 2
make[4]: Leaving directory `/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC/eigerApp'
make[3]: *** [eigerApp.install] Error 2
make[3]: Leaving directory `/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC'
make[2]: *** [eigerIOC.install] Error 2
make[2]: Leaving directory `/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger/iocs'
make[1]: *** [iocs.install] Error 2
make[1]: Leaving directory `/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger'
make: *** [/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger.install] Error 2
Best,
Jong
Re: areaDetector build errors Jong Woo Kim via Tech-talk
Prev: Re: AreaDetector Teledyne driver question Mark Rivers via Tech-talk
Next: Re: AreaDetector Teledyne driver question David Vine via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: areaDetector build errors Jong Woo Kim via Tech-talk
Next: Re: areaDetector build errors Jong Woo Kim via Tech-talk
