1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: RE: Phoebus alarm does not honor filter
From: "Ashwarya, Tanvi via Tech-talk" <[email protected]>
To: Kay Kasemir <[email protected]>, "Zhang, Tong" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 23 Jun 2022 13:56:13 +0000
Hello,
I ran a few tests and found the problem only occurs if alarm delay for test_alarm PV is set to a non-zero value. It does not matter if the test_alarm PV is configured to be latched or unlatched.
When alarm delay is non-zero, PV (in an alarm state) on getting re-enabled (using filter) goes into OK state and hence don’t show up on the alarm table. Until an alarm event (such as alarm state change or acknowledge action) happens on the PV, PV is seen to be stuck in OK state in alarm tree and don’t show up on alarm table.
Tanvi Ashwarya
Tel. 517-908-7776
Email: [email protected]
Sent: Wednesday, June 22, 2022 2:55 PM
To: Zhang, Tong <[email protected]>; [email protected]
Cc: Ashwarya, Tanvi <[email protected]>
Subject: Re: Phoebus alarm does not honor filter
[EXTERNAL] This email originated from outside of FRIB
> In the example you pointed out, where is the alarm configuration for PV ‘test_alarm’? I cannot see this information.
I added the test_alarm PV with enabling filter "test_enable>0" to the alarm tree.
Can you duplicate the issue with the 'test_alarm' and 'test_enable' PVs from the demo.db?
Does latched/unlatched make a difference?
Does the 2 second delay make a difference?
Kay
Re: Phoebus alarm does not honor filter Kasemir, Kay via Tech-talk
RE: Phoebus alarm does not honor filter Zhang, Tong via Tech-talk
Prev: Re: AreaDetector Teledyne driver question David Vine via Tech-talk
Next: Re: Phoebus alarm does not honor filter Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Phoebus alarm does not honor filter Kasemir, Kay via Tech-talk
