1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: StreamDevice return state error
From: "Barrett \(US\), Patrick E via Tech-talk" <[email protected]>
Date: Tue, 28 Jun 2022 16:37:08 +0000
I am working to simulate a SCPI type device with an IOC.  I am using I/O Intr records to read in the SCPI and set the state of the mbbi record.  The IOC should return ERROR if an error occurs, such as if an invalid state is requested. I can see the error message in the IOC when an invalid state is requested, but do not know how to capture the error in the protocol file or db setup to send a return string of “ERROR”.
The error I get is when sending the IOC “SYSTEM:STATE MONITOR” is: ’… RCV_STATE: Record does not accept input "MONITOR"
Proto definition:
readSystemState
   in "SYSTEM:STATE %s";
   out "%(\$1)s";
Record definition:
record(mbbi, "RCV_STATE")
   field(DESC, "SYSTEM:STATE P01")
   field(DTYP, "stream")
   field(SCAN, "I/O Intr")
   field(INP,  "@simCmd.proto readSystemState(STATE_RTN) $(PORT) 0")
   field(ZRST, "STANDBY")
   field(ZRVL, "0")
   field(ONST, "OPERATE")
   field(ONVL, "1")
   field(TWST, "SELFTEST")
   field(TWVL, "2")
   field(UNSV, "INVALID")
record(bi, " STATE_RTN ")
   field(DESC, "State Return")
   field(DTYP, "Soft Channel")
   field(SCAN, "Passive")
   field(ZNAM, "OK")
   field(ONAM, "ERROR")
   field(VAL, 0)
   field(PINI, 1)
Patrick Barrett
Software Engineer
The Boeing Company
RE: StreamDevice return state error Pearson, Matthew via Tech-talk
Re: StreamDevice return state error Zimoch Dirk (PSI) via Tech-talk
Prev: RE: added the pv in synapps Mark Rivers via Tech-talk
Next: RE: StreamDevice return state error Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: added the pv in synapps 网易邮件中心 via Tech-talk
