Hi Patrick,
The error "Record does not accept input" happens when you send a string (parsed with %s) to a record with an enum VAL
like your mbbi, but the string does not match any of the enum strings in the record.
As your record only has "STANDBY", "OPERATE" and "SELFTEST", it does not accept the input "MONITOR".
Dirk
On Tue, 2022-06-28 at 16:37 +0000, Barrett (US), Patrick E via Tech-talk wrote:
> I am working to simulate a SCPI type device with an IOC. I am using I/O Intr records to read in the SCPI and set the
> state of the mbbi record. The IOC should return ERROR if an error occurs, such as if an invalid state is requested. I
> can see the error message in the IOC when an invalid state is requested, but do not know how to capture the error in
> the protocol file or db setup to send a return string of “ERROR”.
> The error I get is when sending the IOC “SYSTEM:STATE MONITOR” is: ’… RCV_STATE: Record does not accept input
> "MONITOR"’
> Proto definition:
> readSystemState
> in "SYSTEM:STATE %s";
> out "%(\$1)s";
> Record definition:
> record(mbbi, "RCV_STATE")
> field(DESC, "SYSTEM:STATE P01")
> field(DTYP, "stream")
> field(SCAN, "I/O Intr")
> field(INP, "@simCmd.proto readSystemState(STATE_RTN) $(PORT) 0")
> field(ZRST, "STANDBY")
> field(ZRVL, "0")
> field(ONST, "OPERATE")
> field(ONVL, "1")
> field(TWST, "SELFTEST")
> field(TWVL, "2")
> field(UNSV, "INVALID")
> record(bi, " STATE_RTN ")
> field(DESC, "State Return")
> field(DTYP, "Soft Channel")
> field(SCAN, "Passive")
> field(ZNAM, "OK")
> field(ONAM, "ERROR")
> field(VAL, 0)
> field(PINI, 1)
> Patrick Barrett
> Software Engineer
> The Boeing Company
- Re: StreamDevice return state error Zimoch Dirk (PSI) via Tech-talk
- StreamDevice return state error Barrett (US), Patrick E via Tech-talk
Re: added the pv in synapps 网易邮件中心 via Tech-talk
<2022>
2025
2026
RE: StreamDevice return state error Pearson, Matthew via Tech-talk
<2022>
2025
2026
