Hi Marco,
On 6/29/22 3:32 PM, Marco A. Barra
Montevechi Filho via Tech-talk wrote:
I
am altering an old OPCUA IOC that was running here in the lab and
i noticed that someone configured several records with the DISS
field set to "INVALID". When the IOC is running, all of these
records have the fields .SEVR set to "INVALID" and this was
messing with some interfaces made with pydm. The records have no
HSV, LSV or similar fields defined and cagetting into DISV and
DISA fields revealed that they are at default value.
I'm assuming the DISS field is responsible for the .SEVR INVALID
value, but searching in the web all i could find about DISS was:
"When this record is disabled, it will be put into alarm with this
severity and a status of DISABLE_ALARM." and this is not clear for
me: shouldnt the records only have "INVALID" value at .SEVR if
they were disabled (which is not the case since DISV and DISA are
at default)?
I altered the DISS field to DISABLE_ALARM and now the records
display NO_ALARM. Is this coherent? Am i altering any other
functionality of the IOC without knowing?
The severity from the DISS field is used and the record's STAT field
set to "DISABLE_ALARM" when the record is prevented from processing
because the value read into DISA through the SDIS link matches that
found in the DISV field. Where were the SDIS links of those records
pointing to? Was their STAT field showing "DISABLE_ALARM" (or
possibly the value 18, since CA only supports up to 16 enumeration
states)?
This mechanism is described on slide 37 of my Database
Principles training lecture.
Often a record's SDIS link will be pointed at a binary or calc
record that is used to enable or disable parts of the IOC database,
because the equipment it controls is not used in that configuration,
or the binary value may reflect whether the device is currently
connected or not.
Just changing the DISS severity won't allow those records to process
if they were being disabled using the SDIS/DISA/DISV mechanism. I
suggest you investigate that further since there may be more to that
database than you originally thought.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Re: Doubts about DISS field Marco A. Barra Montevechi Filho via Tech-talk
- Doubts about DISS field Marco A. Barra Montevechi Filho via Tech-talk
Re: Re: EPICS IOC BOOTP timeout at RTEMS on MVME6100 chengsn via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
