Subject: |
Substitution file, streamdevice |
Donny Domagoj Cosic via Tech-talk <[email protected]> |
To: |
Ralph Lange via Tech-talk <[email protected]> |
Date: |
Mon, 11 Jul 2022 13:58:49 +0200 |
Hello,
I have a user.substitution file that contains a number of entries
(vacuum pumps in this case) and it works well with the IOC. When all the
pumps are connected, the IOC cycles through all the entries in the
substitution file. However if we disconnect one pump, we receive a No
Reply error from StreamDevice and the execution of the substitution file
stops at that entry. The rest of the substitution file is skipped by the
IOC until the next scan cycle where it again begins from the first entry
in the substitution file. Therefore the entries after the No Reply are
never executed.
How can I get the IOC to continue to the next entry in the substitution
file when a No Reply error (for an IN command) is encountered?
Thank you in advance,
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | www.irb.hr
- Re: Substitution file, streamdevice Zimoch Dirk (PSI) via Tech-talk
Re: How to safely implement an asynPortDriver with SCAN records Jure Varlec via Tech-talk
<2022>
2025
2026
PHP_EPICS module Remi Faure via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
