The answer to your question depends strongly on the details of your implementation.
Please provide your substitution file and template.
Dirk
On Mon, 2022-07-11 at 13:58 +0200, Donny Domagoj Cosic via Tech-talk wrote:
> Hello,
> I have a user.substitution file that contains a number of entries
> (vacuum pumps in this case) and it works well with the IOC. When all the
> pumps are connected, the IOC cycles through all the entries in the
> substitution file. However if we disconnect one pump, we receive a No
> Reply error from StreamDevice and the execution of the substitution file
> stops at that entry. The rest of the substitution file is skipped by the
> IOC until the next scan cycle where it again begins from the first entry
> in the substitution file. Therefore the entries after the No Reply are
> never executed.
> How can I get the IOC to continue to the next entry in the substitution
> file when a No Reply error (for an IN command) is encountered?
> Thank you in advance,
- Re: Substitution file, streamdevice Donny Domagoj Cosic via Tech-talk
- Substitution file, streamdevice Donny Domagoj Cosic via Tech-talk
CSS questions pertaining to combo box showing values after decimal point Wang, Andrew via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
