1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Substitution file, streamdevice
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: "Zimoch Dirk (PSI)" <[email protected]>
Cc: [email protected]
Date: Mon, 11 Jul 2022 15:20:24 +0200
Hi Dirk,
Thank you for your reply.
user.substitutions:
file "db/vacuumPumps.db" {
	pattern { name, address, port}
	{ "VDG_LE","001", "PumpPort"}
	{ "VDG_HE","002", "PumpPort"}
	{ "TDT_Ext","003", "PumpPort"}
	{ "TDT_Switching","004", "PumpPort"}
	{ "TDT_90","006", "PumpPort"}
	{ "TDT_HE","007", "PumpPort"}
	{ "TDT_LE","008", "PumpPort"}
	{ "VDG_90A","011", "PumpPort"}
	{ "VDG_90B","012", "PumpPort"}
	{ "VDG_SNICS","013", "PumpPort"}
	{ "VDG_Alphatros","014", "PumpPort"}
	{ "TDT_Injector","015", "PumpPort"}
vacuumPumps.db
record(ai, "Vacuum:Pumps:Current:$(name):Read")
  field(DTYP, "stream")
  field(INP,  "@vacuumPumps.proto pumpCurrent($(address)) $(port)")
  field(SCAN, "10 second")
  field(ESLO, "0.01")
  field(LINR, "LINEAR")
  field(HIHI, "3.00")
  field(HIGH, "1.00")
  field(HHSV, "MAJOR")
  field(HSV, "MINOR")
  field(EGU, "A")
vacuumPumps.proto
pumpCurrent {
   out "\$10031002=?%+<sum>";
   in "%*10d%6d%*3d";
I have included the information you requested. On what does it depend?
Thank you,
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | www.irb.hr
Dana 2022-07-11 14:26, Zimoch Dirk (PSI) je napisao(la):
The answer to your question depends strongly on the details of your
implementation.
Please provide your substitution file and template.
Dirk
On Mon, 2022-07-11 at 13:58 +0200, Donny Domagoj Cosic via Tech-talk wrote:
Hello,
I have a user.substitution file that contains a number of entries
(vacuum pumps in this case) and it works well with the IOC. When all the
pumps are connected, the IOC cycles through all the entries in the
substitution file. However if we disconnect one pump, we receive a No
Reply error from StreamDevice and the execution of the substitution file stops at that entry. The rest of the substitution file is skipped by the IOC until the next scan cycle where it again begins from the first entry
in the substitution file. Therefore the entries after the No Reply are
never executed.
How can I get the IOC to continue to the next entry in the substitution
file when a No Reply error (for an IN command) is encountered?
Thank you in advance,
Re: Substitution file, streamdevice Zimoch Dirk (PSI) via Tech-talk
Substitution file, streamdevice Donny Domagoj Cosic via Tech-talk
Prev: RE: CSS questions pertaining to combo box showing values after decimal point Wang, Andrew via Tech-talk
Next: Re: Substitution file, streamdevice Zimoch Dirk (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Substitution file, streamdevice Zimoch Dirk (PSI) via Tech-talk
