1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Issue with Asyn+StreamDevice on a Raspi CM4
From: "Zimoch Dirk \(PSI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 12 Jul 2022 07:56:33 +0000
Hi Florian,
If the output buffer is not able to accept all bytes at once, then the write() function should have returned 16 instead
of 17 and drvAsynSerialPort writeIt() would try again with the remaining bytes, waiting for writeTimeout and failing
with asynTimeout if it cannot send.
But if the kernel driver implements write() in a way that discards bytes, then all hope is lost.
Try with some other program, for example from the command line:
echo "this is a string longer than 16 chars" > /dev/ttyAMA0
Dirk
On Tue, 2022-07-12 at 09:44 +0200, Florian Feldbauer via Tech-talk wrote:
> Hey all,
> we have a small vacuum chamber to test our sensor modules after production.
> The 2 Pumps and 2 valves are controlled via a Raspberry Pi CM4 running
> linux-aarch64.
> The Turbo pump and digital gauge are from Pfeiffer Vacuum and controlled
> via RS485.
> I noticed some strange issue. I was able to read all parameters from
> those devices, but changing them fails.
> To further investigate I attached a 2nd PC to the RS485 bus just
> listening and found the following:
> > epics> asynSetTraceIOMask rs485, 0, ASYN_TRACEIO_ESCAPE
> > epics> asynSetTraceMask rs485, 0, ASYN_TRACEIO_DRIVER
> > epics> dbpf SCATTERCHAMBER:VACUUM:TP:CtrlViaInt RS485
> > DBF_STRING:         "RS485"
> > 2022/07/12 09:25:52.084 /dev/ttyAMA0 write 17
> > 0011006003002125\r
> > 2022/07/12 09:25:52.721930 rs485 SCATTERCHAMBER:VACUUM:TP:CtrlViaInt:
> > No reply within 500 ms to "0011006003002125<0d>"
> > 2022/07/12 09:25:52.722 /dev/ttyAMA0 write 16
> > 0010006002=?101\r
> > 2022/07/12 09:25:52.762 /dev/ttyAMA0 read 16
> > 0011006003002125
> > 2022/07/12 09:25:52.766 /dev/ttyAMA0 read 1
> > \r
> > epics>
> The 2nd PC received this:
> > Got 16 bytes:
> > 0011006003002125      [30 30 31 31 30 30 36 30 30 33 30 30 32 31 32 35]
> > Got 16 bytes:
> > 0010006002=?101\r     [30 30 31 30 30 30 36 30 30 32 3d 3f 31 30 31 0d]
> > Got 17 bytes:
> > 0011006003002125\r    [30 30 31 31 30 30 36 30 30 33 30 30 32 31 32 35 0d]
> As you can see, on the first message which was send from the IOC, the CR
> is missing.
> I guess the issue is, that asyn tries to write all 17 bytes at once, but
> the tx buffer on the Raspberry Pi can only hold 16 byte, so the CR gets
> lost.
> Is there a way to limit the number of bytes written in a single write
> call with asyn?
> Luckily in this case the length of the telegrams is well known and I
> could simply use 2 OUT statements in my protocol file to work around
> this problem, but what if I want to control a device where the length
> depends on the payload data?
> Cheers,
> Florian
Re: Issue with Asyn+StreamDevice on a Raspi CM4 Florian Feldbauer via Tech-talk
Re: Issue with Asyn+StreamDevice on a Raspi CM4 Zimoch Dirk (PSI) via Tech-talk
Prev: Issue with Asyn+StreamDevice on a Raspi CM4 Florian Feldbauer via Tech-talk
Next: RE: EPICS compilation errors Adrian Martinez via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Re: Issue with Asyn+StreamDevice on a Raspi CM4 Florian Feldbauer via Tech-talk
