1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: ADEiger: eigerDetectorConfig unbale to parse json response
From: John Dobbins via Tech-talk <[email protected]>
Date: Wed, 13 Jul 2022 18:59:23 +0000
All,
I just built areaDetector master, ADEiger master.
ADCore Version 3.12.1
Driver Version    3.4.0
SDK Version        1.8.0
Firmware             release-2020.2.1
Model                  EIGER2 Si 16M
However on IOC startup
eigerDetectorConfig("EIG", "172.30.10.14", 0, 0)
RestApi::get: [param=nexpi] server returned error code 404
2022/07/13 14:30:34.782 Param[NEXPOSURES]::baseFetch: [param=nexpi] unable to parse json response []
2022/07/13 14:30:34.782 Param[NEXPOSURES]::fetch<int>: [param=NEXPOSURES] underlying baseFetch failed
RestApi::get: [param=extg_mode] server returned error code 404
2022/07/13 14:30:35.039 Param[EXT_GATE_MODE]::baseFetch: [param=extg_mode] unable to parse json response []
2022/07/13 14:30:35.039 Param[EXT_GATE_MODE]::fetch<int>: [param=EXT_GATE_MODE] underlying baseFetch failed
then after IOC  init
2022/07/13 14:30:38.085 Param[EXT_GATE_MODE]::baseFetch: [param=extg_mode] unable to parse json response []
2022/07/13 14:30:38.085 Param[EXT_GATE_MODE]::fetch<int>: [param=EXT_GATE_MODE] underlying baseFetch failed
2022/07/13 14:30:38.085 eigerDetector::writeInt32: error status=1 function=144, value=0
2022/07/13 14:30:38.085 EIG16M:cam1:ExtGateMode devAsynInt32::processCallbackOutput process write error
2022/07/13 14:30:39.654 Param[NEXPOSURES]::baseFetch: [param=nexpi] unable to parse json response []
2022/07/13 14:30:39.654 Param[NEXPOSURES]::fetch<int>: [param=NEXPOSURES] underlying baseFetch failed
2022/07/13 14:30:39.654 eigerDetector::writeInt32: error status=1 function=73, value=1
2022/07/13 14:30:39.654 EIG16M:cam1:NumExposures devAsynInt32::processCallbackOutput process write error
The ADEiger documentation reads:  "Depends on the Eiger2 having the firmware 2020.2 or newer" which I satisfy.
I have an older version of ADEiger
Driver Version 2-5
ADCore             3.10.0
which doesn't generate these errors.
Ideas? Thanks.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Prev: Re: issue while creating a device support using ASYN on windows Mark Rivers via Tech-talk
Next: ADEiger acquisiton problem John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
