1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: issue while creating a device support using ASYN on windows
To: Siddharth Vardhan Pratihast <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 13 Jul 2022 12:14:57 +0000
Hi Siddarth,
I have never used the makeSupport.pl script.  But I looked at it quickly and it has -h option for help.
corvette:~/scratch>/home/epics/devel/asyn/bin/linux-x86_64/makeSupport.pl -h
Usage:
    makeSupport.pl -h
        Display help on command options
    makeSupport.pl -l [l-opts]
        List available template types
    makeSupport.pl -t type [t-opts] support
        Create tree for device 'support' from template 'type'
    where
        [l-opts] may be one of:
            -T /path/to/templates
            -A /path/to/asyn
        [t-opts] are any of:
            -A /path/to/asyn
            -B /path/to/base
Example:
    mkdir Keithley196
    cd Keithley196
    <asyn>/bin/<arch>/makeSupport.pl -t devGpib K196
So you can give a -A option to specify the path to asyn.  Did you try using -A?  It worked for me on Linux:
corvette:~/scratch>/home/epics/devel/asyn/bin/linux-x86_64/makeSupport.pl -t devGpib -A /home/epics/devel/asyn isps
Copying .:.......:....:.
Template instantiated.
However, it appears that you are planning to use devGpib.  If you look at the documentation for devGpib you will see that it is obsolete and that you should use StreamDevice instead.
I strongly recommend using StreamDevice instead of devGpib.
From: Siddharth Vardhan Pratihast <[email protected]>
Sent: Wednesday, July 13, 2022 3:56 AM
To: [email protected] <[email protected]>; Mark Rivers <[email protected]>
Subject: issue while creating a device support using ASYN on windows
Dear Sir,
I have successfully built the EPICS Base and ASYN module on windows using strawberry Perl.
When I am running the following Perl script to create a device support using ASYN on command line:
D:\epics\ISPS>..\asyn4-38\bin\windows-x64-mingw\makeSupport.pl -t devGpib isps
I am getting the following error :
expected 'makeSupport.pl', got 'D:\epics\asyn4-38\bin\windows-x64-mingw\makeSupport.pl'
expected 'expected windows-x64-mingw', got ''
expected 'bin', got ''
ASYN directory '' not found!
D:\epics\ISPS>
Environment Variables declared:
EPICS_HOST_ARCH=windows-x64-mingw
EPICS_BASE=D:\epics\base-3.15.9
ASYN=D:\epics\asyn4-38
PATH provided for Strawberry Perl
could you guide me through this?
-Siddharth Pratihast
सिद्धार्थ वर्धन प्रतिहस्त / Siddharth Vardhan Pratihast
वैज्ञानिक अधिकारी / Scientific Officer
कंप्यूटर एवं सूचना वर्ग / Computer and Informatics Group
परिवर्ती उर्जा साइक्लोट्रॉन केंद्र / Variable Energy Cyclotron Centre
परमाणु उर्जा विभाग / Department of Atomic Energy
भारत सरकार / Government of India
1/ए एफ विधान नगर / 1/AF Bidhan Nagar
कोलकाता - 700064 , भारत / Kolkata - 700064, India
फोन / Ph (O): +91-033-23184737
फैक्स / Fax: +91 33 2334 6871
ईमेल / Email :
[email protected]
issue while creating a device support using ASYN on windows Siddharth Vardhan Pratihast via Tech-talk
Prev: issue while creating a device support using ASYN on windows Siddharth Vardhan Pratihast via Tech-talk
Next: ADEiger: eigerDetectorConfig unbale to parse json response John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
