1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: RE: ADEiger acquisiton problem
To: John Dobbins <[email protected]>
Date: Wed, 13 Jul 2022 20:40:52 +0000
Hi John,
Are there any error messages on the IOC console?
Does the Acquire PV go back to done?
Can you send an medm screen shot at the end of the acquisition?
Can you try using Stream mode and see if that works?  I know we have an Eiger2 16M at APS 12-ID that is used in Stream mode and it is working OK.
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Wednesday, July 13, 2022 3:34 PM
To: [email protected]
Subject: ADEiger acquisiton problem
I am encountering a problem with acquisition on an EIGER2 which I haven't experienced before (on other EIGERs)
This appears to be true with both the latest ADEiger and an older version (Driver 2-5, ADCore 3.10.0)
I have an EIGER2 16M, firmware 2020.2.1
If I set TriggerMode = Internal Series, NumImages =1 , AcquireTime = 1.0 and press Start the MEDM screen reports the detector going through all the expected states  (Arming, Triggering, Processing Files) .  An HDF5 master files appears but no data file. Also the image counter does not increment.
External Trigger works as expected.
When tested separately from EPICS (a locally written program sending HTTP requests) the acquisition occurs as expected.
Any advice appreciated.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Re: ADEiger acquisiton problem John Dobbins via Tech-talk
Prev: ADEiger acquisiton problem John Dobbins via Tech-talk
Next: extensions CONFIG_SITE file for linux-aarch64 of Raspberry Pi 64-bit OS Akira Chen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Re: ADEiger acquisiton problem John Dobbins via Tech-talk
