1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: ADEiger acquisiton problem
From: John Dobbins via Tech-talk <[email protected]>
Date: Thu, 14 Jul 2022 14:23:23 +0000
Mark,
External Enable, External Series, Internal Enable work as expected.
Internal Series generates only a master file.  Acquire Staus = Done after acquisition. Image Counter does not increment. There are no messages at the IOC console.
Attached an image post Internal Series acquisition. I set image counter to zero before acquisition.
Internal Series seems to work with stream. The image counter increments. The plugin NDFileHDF5 writes a file if enabled.
John
Sent: Wednesday, July 13, 2022 4:40 PM
To: John Dobbins <[email protected]>
Subject: RE: ADEiger acquisiton problem
Hi John,
Are there any error messages on the IOC console?
Does the Acquire PV go back to done?
Can you send an medm screen shot at the end of the acquisition?
Can you try using Stream mode and see if that works?  I know we have an Eiger2 16M at APS 12-ID that is used in Stream mode and it is working OK.
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Wednesday, July 13, 2022 3:34 PM
To: [email protected]
Subject: ADEiger acquisiton problem
I am encountering a problem with acquisition on an EIGER2 which I haven't experienced before (on other EIGERs)
This appears to be true with both the latest ADEiger and an older version (Driver 2-5, ADCore 3.10.0)
I have an EIGER2 16M, firmware 2020.2.1
If I set TriggerMode = Internal Series, NumImages =1 , AcquireTime = 1.0 and press Start the MEDM screen reports the detector going through all the expected states  (Arming, Triggering, Processing Files) .  An HDF5 master files appears but no data file. Also the image counter does not increment.
External Trigger works as expected.
When tested separately from EPICS (a locally written program sending HTTP requests) the acquisition occurs as expected.
Any advice appreciated.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Attachment: cornell_eiger16m_post_internal_series.png
Description: cornell_eiger16m_post_internal_series.png
Re: ADEiger acquisiton problem Mark Rivers via Tech-talk
ADEiger acquisiton problem John Dobbins via Tech-talk
RE: ADEiger acquisiton problem Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] Phoebus Alarm Area Panel custom colours Kasemir, Kay via Tech-talk
Next: Re: [EXTERNAL] Phoebus Alarm Area Panel custom colours Ian Gillingham via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: RE: ADEiger acquisiton problem Mark Rivers via Tech-talk
Next: Re: ADEiger acquisiton problem Mark Rivers via Tech-talk
