1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: How to safely implement an asynPortDriver with SCAN records
From: Érico Nogueira Rolim via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>, Mark Rivers <[email protected]>, Andrew Johnson <[email protected]>
Date: Wed, 20 Jul 2022 11:18:09 -0300
On 08/07/2022 17:37, Michael Davidsaver wrote:
On 7/8/22 11:11, Mark Rivers via Tech-talk wrote:
Hi Andrew,
To be honest I have not paid enough attention to how to correctly
handle destructors in asynPortDriver.
On the occasions when I've used asynPortDriver, I put a cantProceed()
in the sub-class destructor.
Can you say where exactly in the destructor you used cantProceed()? I
can't seem to make it behave correctly: the IOC never exits, though it
does dump a stack trace.
After a call to registerInterface(), the asynInterface::drvPvt pointer
must remain valid until
the process exits.  So an asyn port can't be destroyed.
I've toyed with the ideas like re-counter asynUser, or somehow later
setting drvPvt=NULL.
Both seem possible, but not without quite some effort.
This situation is made more complicated by the fact that IOC scan
threads are not stopped on exit.
We do now stop them during database unit tests.  However, some ~vague
compatibility concerns have
so far kept this from being done for full IOCs.
Where does this choice happen? Could one do it for their own IOC?
Personally, as a matter of good practice, drivers I write always
include an epicsAtExit() handler
which stops any worker threads.
Also, I should mention the de-init hooks added in Base 7.0.4 to
decouple database shutdown from
process exit.
https://github.com/epics-base/epics-base/commit/5d5e552a7ec6ef69459c97b0081aa775372a6290#diff-02e4602d43dbb03b4097bb26382a1db92367fb55fe791415cd32d4f234875d92R50
For compatibility, the effect of initHookAtShutdown can mostly be
replicated by calling epicsAtExit()
at initHookAfterIocRunning.
If I understand correctly, what I'd want for my own code would be
calling the driver's destructor in initHookAfterStopScan? If it ran for
full IOCs, of course.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: How to safely implement an asynPortDriver with SCAN records Jure Varlec via Tech-talk
How to safely implement an asynPortDriver with SCAN records Érico Nogueira Rolim via Tech-talk
RE: How to safely implement an asynPortDriver with SCAN records Mark Rivers via Tech-talk
Re: How to safely implement an asynPortDriver with SCAN records Érico Nogueira Rolim via Tech-talk
Re: How to safely implement an asynPortDriver with SCAN records Andrew Johnson via Tech-talk
Re: How to safely implement an asynPortDriver with SCAN records Michael Davidsaver via Tech-talk
Prev: Re: Automatically populating the Archive Appliance Tynan Ford via Tech-talk
Next: Re: How to safely implement an asynPortDriver with SCAN records Jure Varlec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: How to safely implement an asynPortDriver with SCAN records Jure Varlec via Tech-talk
