1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: [EXTERNAL] Phoebus Scan Server
From: "Pearson, Matthew via Tech-talk" <[email protected]>
To: Ian Gillingham <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 21 Jul 2022 14:34:21 +0000
Hi Ian,
The scan server is used at the SNS for all the beamlines, and at about half of the beamlines at HFIR, about 25 beamlines total. It is the main automation tool and we use it in a variety of ways. I'll send you a PowerPoint presentation explaining in more detail and showing screenshots.
It's been a very useful and reliable part of our control system, and we are planning to keep using it for the SNS Second Target Station. One of the main advantages is that it runs on a remote server and multiple instances of CS-Studio can see what's going on. It's possible to build up complex workflows using the scan server, such as beamline alignment applications, as scans can be queued up, waited on (by polling the state), automatically paused, etc.
Most communication to our scan server goes though the PyScanClient library:
https://controlssoftware.sns.ornl.gov/css_pyscanclient/html/
Or via scripts running inside CS-Studio.
So we build and submit scans in different ways:
1) Using a spreadsheet-like interface called a table scan (a screen in CS-Studio), which can be populated from a CSV file.
2) Using Python IOC applications (using PyScanClient), via an interface screen in CS-Studio.
3) Via standalone Python scripts.
The CS-Studio scan editor is useful for testing, but I wouldn't say that is routinely used. The scan monitor is always used. On every beamline at SNS and HFIR we will usually see the scan monitor window open.
I'm sure Kay will reply as well, and correct anything I said, since he is the main developer of the scan server.
Cheers,
Matt
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Ian Gillingham via Tech-talk
Sent: Thursday, July 21, 2022 8:36 AM
To: [email protected]
Subject: [EXTERNAL] Phoebus Scan Server
The Scan Server that's packaged with Phoebus looks, on the face of it, as though it could fulfill a major part of a project requirement - i.e.
automated sequences of operations. I've built some small test scripts (.scn XML files) and submitted them to a locally running scan server - it all looks quite slick, especially as Phoebus has a scan editor and monitor built in.
Before incorporating it into a system design, I'm interested to know whether anyone else uses it as an integral part of their control systems and what your experiences have been?
Ian
Ian Gillingham
Phoebus Scan Server Ian Gillingham via Tech-talk
Prev: CS-Studio: File Manager configuration when executing external command Zhang, Tong via Tech-talk
Next: Re: [EXTERNAL] Phoebus Scan Server Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Phoebus Scan Server Ian Gillingham via Tech-talk
