1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: CS-Studio: File Manager configuration when executing external command
From: "Zhang, Tong via Tech-talk" <[email protected]>
To: Kay Kasemir <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 21 Jul 2022 15:05:43 +0000
Kay, I’m talking about CS-Studio on Eclipse, not Phoebus.
The difference is the highlighted in the box, where I created a bookmark called datafiles, but it could not be seen in the Open dialog in CS-Studio, I forgot to mention, it is not necessary happening with external app calling, but from any Open action from CS-Studio, e.g. Open an OPI through the menu.
I also tested against Phoebus, it works without such issue. But I’m looking for a solution for CS-Studio.
Tong
Sent: Thursday, July 21, 2022 10:59
To: [email protected]; Zhang, Tong <[email protected]>
Subject: Re: CS-Studio: File Manager configuration when executing external command
[EXTERNAL] This email originated from outside of FRIB
> After the external application is started up through the “Execute Command” action of an ActionButton, everything looks to be working well, but when doing the save/open businesses through the external app interface, it seems that the current user File Manager configuration is not being honored, e.g. you cannot see any bookmarked locations on the pop-up file/directory open dialog
Not sure what the difference is, but that works for me in the most recent version of CS-Studio, i.e. the one that no longer relies on Eclipse.
I've opened gedit, added a "tmp" bookmark to its file locator.
Then I opened CS-Studio/phoebus, opened the example displays, "Actions", "Open *.def file" which on Linux opens gedit, opened the file locator in gedit -> It shows the "tmp" bookmark.
-Kay
CS-Studio: File Manager configuration when executing external command Zhang, Tong via Tech-talk
Re: CS-Studio: File Manager configuration when executing external command Kasemir, Kay via Tech-talk
Prev: Re: CS-Studio: File Manager configuration when executing external command Kasemir, Kay via Tech-talk
Next: Re: [EXTERNAL] Phoebus Scan Server Ian Gillingham via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: PyDevice modbus liuxiaomin via Tech-talk
